Home » Modeling » Papyrus » Opening a papyrus UML diagram editor programatically
Opening a papyrus UML diagram editor programatically [message #559056] Wed, 15 September 2010 09:17 Go to next message
budadam  is currently offline budadam
I tried to open a UML class diagram editor programatically. I was able to open the diagram but synchronization between the resources failed.
How to create synchronization between .notation, .uml and .di files?
Thanks in advance.
Budadam.
Re: Opening a papyrus UML diagram editor programatically [message #559231 is a reply to message #559056] Thu, 16 September 2010 02:48 Go to previous messageGo to next message
Vincent   is currently offline Vincent
Member
Normally, once the editor has opened with te correct file, it should manage this synchronization on its own.
Did you open the editor on the .di file ?
What is the code you used to open the diagram ?
(since there are many different possible ways to do so...)
Re: Opening a papyrus UML diagram editor programatically [message #607456 is a reply to message #559056] Thu, 16 September 2010 02:48 Go to previous message
Member
Previous Topic:Dragging existing SysML blocks into block definition diagrams doesn't work
Next Topic:Unable to discover Papyrus component
Current Time: Sat May 25 05:42:45 EDT 2013
Powered by FUDForum. Page generated in 0.01615 seconds
