Home » Eclipse Projects » BIRT » Optional Y Series Grouping
Optional Y Series Grouping [message #558391] Sun, 12 September 2010 08:10 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
I created a chart with one x-axis, two y-axis and one optional Y series grouping in chart editor. All shows fine.
Now i want to use script for building my second series, because i want to add it dynamically.
My problem is, i don`t know how to do it when i use the optional y series grouping. In my Legend, there are missing the names.
Thanks for help.
Thats my implementation in beforeFactory:
importPackage(Packages.java.util);
importPackage(Packages.org.eclipse.birt.chart.model.data.impl);
importPackage(Packages.org.eclipse.birt.chart.model.component.impl);
importPackage(Packages.org.eclipse.birt.chart.model.type.impl);
importPackage(Packages.org.eclipse.birt.chart.model.attribute);
importPackage(Packages.org.eclipse.birt.chart.model.attribute.impl);
importPackage(Packages.org.eclipse.birt.chart.model.impl);
importPackage(Packages.org.eclipse.birt.chart.model.component);
cht = reportContext.getDesignHandle().findElement("MyChart");
mychart = cht.getReportItem().getProperty("chart.instance");
xAxis = mychart.getAxes().get(0);
yAxis = xAxis.getAssociatedAxes().get(0);
for(i=2; i<3; i++) {
        var sdNew = SeriesDefinitionImpl.create();
        var ls = LineSeriesImpl.create();
        var qry = QueryImpl.create("row[\"CUSTOMERNUMBER\"]");
        ls.getDataDefinition().add(qry);
        ls.getLineAttributes().setColor(ColorDefinitionImpl.BLACK());
        ls.getMarkers().clear();
        sdNew.getSeries().add(ls);
        yAxis.getSeriesDefinitions().add(sdNew);
I have another question to thir forum. How can i insert screenshots? Is it possible?
Re: Optional Y Series Grouping [message #558638 is a reply to message #558391] Mon, 13 September 2010 18:22 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Are you using the sample db for this? If so can you post the whole
report? Just select the xml view and post the xml.
If you are using the web interface at www.eclipse.org/forums there is an
icon in the editor to add an image.
Jason
On 9/12/2010 4:10 AM, paulina.bastek@gmail.com wrote:
> Thanks for help.
> importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
> importPackage(Packages.org.eclipse.birt.chart.model.componen t.impl);
> importPackage(Packages.org.eclipse.birt.chart.model.type.imp l);
> importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
> importPackage(Packages.org.eclipse.birt.chart.model.attribut e.impl);
> importPackage(Packages.org.eclipse.birt.chart.model.componen t);
> ls.getLineAttributes().setColor(ColorDefinitionImpl.BLACK()) ;
> it possible?
> Thanks
Previous Topic:Yellowfin releases fact sheet on In-memory analysis
Next Topic:Format date parameter for SQL query
Current Time: Fri May 25 22:51:24 GMT 2018
Powered by FUDForum. Page generated in 0.01953 seconds
