Re: Missing "Object Constraint Language (OCL) 2.0 Compatibility API" [message #558513 is a reply to message #558350] |
Mon, 13 September 2010 09:55 |
Adolfo Sanchez-Barbudo Herrera Messages: 260 Registered: July 2009 |
Benjamin,
The set of org.eclipse.emf.ocl.* plugins/features have been deprecated
since time ago, when the set of org.eclipse.ocl.* appeared (in Europe
release if I'm not wrong).
The OCL team decided to throw away the set of org.eclipse.emf.ocl.* in
Helios release. Although the org.eclipse.emf.ocl.* source are still
available (http://www.eclipse.org/modeling/mdt/downloads/?project=ocl -
1.3.0 (2009/06/15) ), I encourage you to switch your client code to use
the set of org.eclipse.ocl.* plugins/features since we have not tested
that the org.eclipse.emf.ocl.* plugins/features work in an Helios
installation.
Since the org.eclipse.emf.ocl API delegates to the org.eclipse.ocl one,
it could be plausible that it worked. However, there was a major version
increment (MDT/OCL 3.0.0) so it's possible that the something could have
broken the org.eclipse.emf.ocl code
Anyway, as said, I recommend switching to the org.eclipse.ocl
plugins/features. It's up to you.
Adolfo.
El 11/09/2010 14:28, Benjamin escribió:
> Hi all,
> we have an eclipse extension with the dependency on org.eclipse.emf.ocl
> that is called "Object Constraint Language (OCL) 2.0 Compatibility API".
> Now, I am checking the upgrade of our environment from galileo to
> helios. Unfortunately, I am not able to find the plugin with the id
> org.eclipse.emf.ocl anymore. Does anybody know where this has gone?
> Thanks a lot!
> Benjamin
FUDForum. Page generated in 0.02480 seconds
