Home » Modeling » Papyrus » Layout bugs(Pretty sure it's not a feature)
Layout bugs [message #558228] Fri, 10 September 2010 15:30
Yannick Duchene (Hibou57) is currently offline Yannick Duchene (Hibou57)Friend
Member
I am not a Papyrus guru, while I am still sure these are not features, and really bugs.
Three layout bugs:
1) In a class diagram, add a package, draw some primitive types and classes, and draw some dependency associations between primitive types and classes. Then, select an association link and drag the attachment point. One thing oftenly occurs : the end point of the associations suddenly change its target and target the containing container instead. When this occurs, there is no way to make it target again its original target.
Then, try to remove that association from the model explorer: you will see the association is still in the diagram, while it does not appears any more in the model explorer. Closing and restarting Eclipse does not change anything.
2) Changing the grid sizes does not apply at all, unless Eclipse is closed and restarted.
3) Also noticed Auto Size seems really broken. Apply Auto Size on a package containing multiple classes, makes the package picture so small it has to be scrolled a lot to view part of what it contains.
Previous Topic:Icons for stereotypes
Next Topic:Layout bugs
Current Time: Wed Apr 25 11:06:14 GMT 2018
Powered by FUDForum. Page generated in 0.01216 seconds
