Home » Eclipse Projects » BIRT » Problems setting the locale manually
Problems setting the locale manually [message #557927] Thu, 09 September 2010 08:46 Go to next message
Eclipse User
Originally posted by: vm.vm.com
I have an application where I read a .rptdesign file from disk. I then want
to set the locale on the corresponding ReportDesignHandle during runtime to
make sure the right report resources are used (this is not always supposed
to be the current machine locale).
public void init(ReportDesignHandle rpt) {
setLocale(rpt, ULocale.ENGLISH);
saveDesign(rpt);
public void setLocale(ReportDesignHandle rpt, ULocale locale) {
try {
rpt.setLocale(locale);
// rpt.setLocale(new ULocale("en_GB"));
// rpt.setLocale(ULocale.ENGLISH);
} catch (SemanticException e) {
logger.error("Locale: " + "not supported", e);
public void saveDesign(ReportDesignHandle rpt) {
rpt.saveAs("c:\test\test.rptdesign");
but when I open the test.rptdesign file it still uses the default
..properties (labels.properties) file instead of the english version
(labels_en_GB.properties).
Is it not possible to update the locale like this during runtime?
Earliere I did:
rpt.setResourceFolder("dir-with-properties-files");
rpt.setIncludeResource("selected-lang-properties-file");
but I hope its possible to avoid this through setting the locale instead...
Re: Problems setting the locale manually [message #557979 is a reply to message #557927] Thu, 09 September 2010 12:42 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Can you try:
rpt.setStringProperty("locale", "de_DE");
You can also set the locale for the task when running the report like:
task.setLocale(new Locale("en", "US"));
Jason
> want to set the locale on the corresponding ReportDesignHandle during
> runtime to make sure the right report resources are used (this is not
> always supposed to be the current machine locale).
> saveDesign(rpt);
> try {
> Earliere I did:
Jason Weathersby
BIRT Exchange
Re: Problems setting the locale manually [message #558099 is a reply to message #557979] Fri, 10 September 2010 03:58 Go to previous messageGo to next message
Eclipse User
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:i6b2n1$agd$1@build.eclipse.org...
> Can you try:
Thanks that works! Out of curiosity why is there a difference between:
rpt.setStringProperty("locale", "en_GB");
Re: Problems setting the locale manually [message #558235 is a reply to message #558099] Fri, 10 September 2010 11:33 Go to previous message
I believe this may be a bug. Any chance you can log it?
Using the setLocale should work.
Jason
>> Can you try:
Jason Weathersby
BIRT Exchange
Previous Topic:Joint Dataset
Next Topic:Libraries conflicts on xml apis [websphere-WAS 6]
Current Time: Thu May 23 17:12:20 EDT 2013
Powered by FUDForum. Page generated in 0.02233 seconds
