Home » Eclipse Projects » BIRT » customized report by windows folder files
icon4.gif  customized report by windows folder files [message #557899] Thu, 09 September 2010 07:32 Go to next message
francesco  is currently offline francesco
i have just installed BIRT on my home pc.....
i'd like to make a customized report using data stored on a folder on my own pc folder. i have a windows s.o,
Is this possible without loading data into a db?
I know a little of java languages and i can't install a data base on my own pc...
Please someone can help me with this kind of situations?
Francesco....Very Happy
Re: customized report by windows folder files [message #558000 is a reply to message #557899] Thu, 09 September 2010 13:36 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
How is the data stored? In a flat file?
Jason
On 9/9/2010 7:32 AM, francesco wrote:
> own pc...
> Francesco....:d
Jason Weathersby
BIRT Exchange
Re: customized report by windows folder files [message #558195 is a reply to message #558000] Fri, 10 September 2010 09:40 Go to previous messageGo to next message
Hi Jason,
thank a lot for your interest about my situation Very Happy
i have to make e customized report having some file from evt security log of my own pc.....
the problem is that i don't have a db and i can't install one on my home pc.
So i want to use the file exctracetd on a folder cerated on my pc to make a data source file in order to BIRT recognize the folder like a data base....
I have read some articles about this trick and i have undestood i have to use a java code to do this but i don't know how to make that.
Can you tell me if this is possible and how to make it?
Francesco :D:D:D:D
Re: customized report by windows folder files [message #558242 is a reply to message #558195] Fri, 10 September 2010 11:50 Go to previous message
BIRT does not have to get data from a db. BIRT can read csv, tsv, psv
type files. So if your files are in a delimited format you should be
able to just use the flat file datasource wizard to get your data.
Jason
On 9/10/2010 9:40 AM, francesco wrote:
> Hi Jason,
> thank a lot for your interest about my situation :d
> pc.
> data base....
> Best regards,
> Francesco :D:D:D:D
Jason Weathersby
BIRT Exchange
Previous Topic:Libraries conflicts on xml apis [websphere-WAS 6]
Next Topic:Birt 2.5.2 : Number of page
Current Time: Wed Jun 19 09:59:47 EDT 2013
Powered by FUDForum. Page generated in 0.01544 seconds
