Home » Eclipse Projects » BIRT » Text not localized automatically
Text not localized automatically [message #557869] Thu, 09 September 2010 09:48 Go to next message
Originally posted by: vm.vm.com
I have created a .rptdesign file in a folder 'test'. In the same folder I
have put the files:
labels_de_DE.properties
labels_en_GB.properties
each containing a single key 'label1' with the value:
das its ein deutches label
this is a english label
I have then attached the "labels_en_GB.properties" file as a resource to the
..rptdesign file. On a label in the report I assign the key 'label1' and when
I preview it shows up fine in english.
I then go to preferences->preview and change the locate to german and
preview again. But the text is still in english. Should birt not
automatically select the right .properties file?
Re: Text not localized automatically [message #557921 is a reply to message #557869] Thu, 09 September 2010 12:21 Go to previous message
Problem solved needed to specify a default lang file:
http://www.birt-exchange.org/org/forum/index.php/topic/19990 -birt-viewer-is-not-changing-localization-of-reports/page__s __a1ec02495914d01862647ba1cacc2070
"vm" <vm@vm.com> wrote in message news:i6aao8$jse$1@build.eclipse.org...
> have put the files:
> the .rptdesign file. On a label in the report I assign the key 'label1'
> and when I preview it shows up fine in english.
Previous Topic:customized report by windows folder files
Next Topic:Setting table groups in code (conditional grouping)
Current Time: Mon Jun 18 12:04:41 GMT 2018
Powered by FUDForum. Page generated in 0.01573 seconds
