Home » Eclipse Projects » BIRT » Joint Dataset(Query on Joint Dataset)
icon14.gif  Joint Dataset [message #557595] Wed, 08 September 2010 08:44 Go to next message
Nilesh Gundecha is currently offline Nilesh GundechaFriend
Hello Everyone,
I am having a requirement of firing a query on Joint Data Set.
Basically, I have created one Joint Data Set from 2 Data Set, which are from different Data Source.
There are 2 fields in this Joint Data Set namely, USERID and GROUPID.
I want to get the count of GROUPID based on User.
But I am not able to find any place in Joint Data Set where should I fire the query for meeting this requirement.
Please help me. Any help will be highly appreciated.
Nilesh.
[Updated on: Wed, 08 September 2010 09:31]
Report message to a moderator
Re: Joint Dataset [message #557758 is a reply to message #557595] Wed, 08 September 2010 18:20 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Nilesh,
You can do this in a table when the joint dataset is used. Just add the
aggregation element. Take a look at the attached example. Note in the
example that the table header and detail row are hidden using the
visibility expression.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Customers" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property
name="displayName">CUSTOMERNAME</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select
CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER, CLASSICMODELS.CUSTOMERS.CUSTOMERNAME
from CLASSICMODELS.CUSTOMERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Order" id="10">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orders]]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:position>7</design:position>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
]]></xml-property>
</oda-data-set>
<joint-data-set name="JointDS" id="11">
<structure>
<property
name="columnName">Order::ORDERNUMBER</property>
<property name="alias">ORDERNUMBER</property>
<text-property
name="displayName">Order::ORDERNUMBER</text-property>
</structure>
<structure>
<property
name="columnName">Customers::CUSTOMERNUMBER</property>
<property
name="alias">Customers::CUSTOMERNUMBER</property>
<text-property
name="displayName">Customers::CUSTOMERNUMBER</text-property >
</structure>
<structure>
<property name="columnName">Order::COMMENTS</property>
<property name="alias">COMMENTS</property>
<text-property
name="displayName">Order::COMMENTS</text-property>
</structure>
<structure>
<property
name="columnName">Order::SHIPPEDDATE</property>
<property name="alias">SHIPPEDDATE</property>
<text-property
name="displayName">Order::SHIPPEDDATE</text-property>
</structure>
<structure>
<property
name="columnName">Order::REQUIREDDATE</property>
<property name="alias">REQUIREDDATE</property>
<text-property
name="displayName">Order::REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">Order::STATUS</property>
<property name="alias">STATUS</property>
<text-property
name="displayName">Order::STATUS</text-property>
</structure>
<structure>
<property
name="columnName">Order::CUSTOMERNUMBER</property>
<property name="alias">Order::CUSTOMERNUMBER</property>
<text-property
name="displayName">Order::CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">Order::ORDERDATE</property>
<property name="alias">ORDERDATE</property>
<text-property
name="displayName">Order::ORDERDATE</text-property>
</structure>
<structure>
<property
name="columnName">Customers::CUSTOMERNAME</property>
<property name="alias">CUSTOMERNAME</property>
<text-property
name="displayName">Customers::CUSTOMERNAME</text-property >
</structure>
</list-property>
<structure>
<property
name="name">Customers::CUSTOMERNUMBER</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="position">8</property>
</structure>
<structure>
<property name="position">9</property>
<property
name="name">Order::CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<simple-property-list name="dataSets">
<value>Customers</value>
<value>Order</value>
</simple-property-list>
<list-property name="joinConditions">
<structure>
<property name="joinType">inner</property>
<property name="joinOperator">eq</property>
<property name="leftDataSet">Customers</property>
<property name="rightDataSet">Order</property>
<expression
name="leftExpression">dataSetRow["CUSTOMERNUMBER"]</expression >
<expression
name="rightExpression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
</joint-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="12">
<property name="dataSet">JointDS</property>
<list-property name="boundDataColumns">
<structure>
<property
<text-property
<expression name="expression"
type="javascript">dataSetRow["Customers::CUSTOMERNUMBER"] </expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["STATUS"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["COMMENTS"]</expression>
</structure>
<structure>
<property name="name">Order::CUSTOMERNUMBER</property>
<text-property
type="javascript">dataSetRow["Order::CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<property name="name">Aggregation</property>
<simple-property-list name="aggregateOn">
<value>NewTableGroup1</value>
<property
name="aggregateFunction">COUNTDISTINCT</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression name="value"
type="javascript">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
</structure>
</list-property>
<column id="61"/>
<column id="62"/>
<column id="89"/>
<header>
<row id="13">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">true</expression>
</structure>
</list-property>
<cell id="14">
<label id="15">
<text-property
name="text">Customers::CUSTOMERNUMBER</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">Customers::CUSTOMERNAME</text-property>
</label>
</cell>
<cell id="84">
<label id="90">
<text-property
name="text">Order::ORDERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="70">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["Customers::CUSTOMERNUMBER"]</expression >
<structure name="toc">
<expression name="expressionValue"
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="71">
<cell id="72">
<data id="83">
<property
name="resultSetColumn">Customers::CUSTOMERNUMBER</property >
</data>
</cell>
<cell id="73">
<data id="92">
<property
name="resultSetColumn">Aggregation</property>
</data>
</cell>
<cell id="85"/>
</row>
</header>
<footer>
<row id="77">
<cell id="78"/>
<cell id="79"/>
<cell id="87"/>
</row>
</footer>
</group>
<detail>
<row id="32">
<structure>
</structure>
</list-property>
<cell id="33">
<data id="34">
<property
</data>
</cell>
<cell id="35">
<data id="36">
<property
name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="86">
<data id="91">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="51">
<cell id="52"/>
<cell id="53"/>
<cell id="88"/>
</row>
</footer>
</table>
</body>
</report>
On 9/8/2010 4:44 AM, Nilesh Gundecha wrote:
> Hello Everyone,
> But I am bot able to find any place in Joint Data Set where should I
> Nilesh.
Re: Joint Dataset [message #557811 is a reply to message #557595] Thu, 09 September 2010 04:59 Go to previous messageGo to next message
Thanks for your reply Jason.
I tried adding computed column. But I could not get the count of GroupId based on UserId. I dont know how it has to be done.
The code u sent is full of XML tags. I have created report using Eclipse, so I am not comfortable with these XML tags.
I request you to please elaborate how can i acheive my requirement. I will be very much thankful to you.
Nilesh.
Re: Joint Dataset [message #557971 is a reply to message #557811] Thu, 09 September 2010 16:11 Go to previous messageGo to next message
Nilesh,
The example implements the feature you (I think) need on the table not
the dataset. Create a new report in the designer. Select the xml tab
at the bottom and replace all the xml with the xml from my earlier post.
Jason
> Nilesh.
icon14.gif  Re: Joint Dataset [message #558128 is a reply to message #557971] Fri, 10 September 2010 09:35 Go to previous message
Hi Jason,
Thanks very much. I studied your given example. And with its help I could easily meet my requirement. Thanks a lot.
Nilesh.
Previous Topic:Setting table groups in code (conditional grouping)
Next Topic:Problems setting the locale manually
Current Time: Sun Jan 21 01:03:49 GMT 2018
Powered by FUDForum. Page generated in 0.01883 seconds
