Home » Eclipse Projects » BIRT » Column width Overflow(Need to extend column past end of column)
Column width Overflow [message #557234] Mon, 06 September 2010 08:30 Go to next message
Chris  is currently offline Chris Friend
Member
Please excuse a real newby to BIRT. I am used to crystal reports and am trying to work out how BIRT achieves the same results.
I need to be able to extend the group heading fields past the end of the column rather than word wrap.
eg
CUSTOMER Customer Order Number
Number
Anna's Decorations,
Ltd
276 Anna's Decorations, 10148
Ltd
276 Anna's Decorations, 10169
Ltd
276 Anna's Decorations, 10370
Ltd
276 Anna's Decorations, 10391
Ltd
I would like to see
CUSTOMER Customer Order Number --heading
Number
Anna's Decorations, Ltd --group
Ltd
Ltd
Ltd
Ltd
in the above case the group field customer name (Anna's Decorations, Ltd) has extended into the next column's space (Customer) as there is no field in the second column for the group. Similar to how data is shown in Excel when the adjacent column is empty.
The problem is the detail lines contain many columns and to fit them in I need the wider group data fields to overlap several detail columns. Any help would be appreciated.
Version 3.5.2 Build M20100211-1343
Any ideas.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<text-property name="displayName"></text-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="28">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">STATE</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,CLASSICMODELS.CUSTOME RS.CUSTOMERNAME,
CLASSICMODELS.ORDERS.ORDERNUMBER,CLASSICMODELS.ORDERS.ORDERD ATE,
CLASSICMODELS.ORDERS.REQUIREDDATE,CLASSICMODELS.ORDERS.SHIPP EDDATE,
CLASSICMODELS.CUSTOMERS.CITY,CLASSICMODELS.CUSTOMERS.STATE
from CLASSICMODELS.CUSTOMERS
join CLASSICMODELS.ORDERS on CLASSICMODELS.ORDERS.CUSTOMERNUMBER=CLASSICMODELS.CUSTOMERS. CUSTOMERNUMBER
where CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER=276]]></xml-property >
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="8">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
<column id="65"/>
<column id="24"/>
<column id="58"/>
<column id="25"/>
<column id="26"/>
<column id="27"/>
<header>
<row id="30">
<property name="textAlign">left</property>
<cell id="62">
<label id="66">
<text-property name="text">CUSTOMER Number</text-property>
</label>
</cell>
<cell id="31">
<text id="29">
<property name="contentType">auto</property>
<text-property name="content"><![CDATA[Customer]]></text-property>
</text>
</cell>
<cell id="55">
<text id="35">
<text-property name="content"><![CDATA[Order Number]]></text-property>
</text>
</cell>
<cell id="32">
<label id="37">
<text-property name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="33">
<label id="39">
<text-property name="text">REQUIREDDATE</text-property>
</label>
</cell>
<cell id="34">
<label id="41">
<text-property name="text">SHIPPEDDATE</text-property>
</label>
</cell>
</row>
</header>
<group id="68">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr" type="javascript">row["CUSTOMERNAME"]</expression>
<structure name="toc">
<expression name="expressionValue" type="javascript">row["CUSTOMERNAME"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="69">
<cell id="70">
<data id="83">
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="71"/>
<cell id="72"/>
<cell id="73"/>
<cell id="74"/>
<cell id="75"/>
</row>
</header>
<footer>
<row id="76">
<cell id="77"/>
<cell id="78"/>
<cell id="79"/>
<cell id="80"/>
<cell id="81"/>
<cell id="82"/>
</row>
</footer>
</group>
<detail>
<row id="14">
<cell id="63">
<data id="67">
<property name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
<cell id="15">
<data id="60">
</data>
</cell>
<cell id="56">
<data id="36">
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="16">
<data id="38">
<property name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="17">
<data id="40">
<property name="resultSetColumn">REQUIREDDATE</property>
</data>
</cell>
<cell id="18">
<data id="42">
<property name="resultSetColumn">SHIPPEDDATE</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="19">
<cell id="64"/>
<cell id="20"/>
<cell id="57"/>
<cell id="21"/>
<cell id="22"/>
<cell id="23"/>
</row>
</footer>
</table>
</body>
</report>
Chris
Re: Column width Overflow [message #557293 is a reply to message #557234] Mon, 06 September 2010 14:11 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
Merge as many adjacent cells in the group header row as you need to have room for the full name.
icon10.gif  Re: Column width Overflow [message #557340 is a reply to message #557234] Mon, 06 September 2010 22:41 Go to previous message
Member
Thanks very much
chris Very Happy
Previous Topic:Get xpath from a selected column?
Next Topic:attach sources to BIRT jars
Current Time: Tue Jun 19 14:46:50 GMT 2018
Powered by FUDForum. Page generated in 0.02331 seconds
