Home » Eclipse Projects » BIRT » attach sources to BIRT jars
attach sources to BIRT jars [message #556956] Fri, 03 September 2010 10:45 Go to next message
asenserini is currently offline asenseriniFriend
I would like to attach the sources to the jars inside the platform/plugin folder so I can debug through the code. What is the best way to do it in Eclipse?
Thanks.
Re: attach sources to BIRT jars [message #557039 is a reply to message #556956] Fri, 03 September 2010 17:01 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Are you debugging an API example or are you wanting to attach to
something like tomcat and debug it?
Jason
> Thanks.
Re: attach sources to BIRT jars [message #557054 is a reply to message #557039] Fri, 03 September 2010 19:26 Go to previous messageGo to next message
I have a web project and added the plugin folder (taken from the report engine download) under the WEB-INF folder. I would like to step through the code whose jars are in the plugin folder. I can do that for the jars in the lib folder (coreapi.jar, dteapi.jar, etc) since I added them in the classpath and attached the sources to them but I am not be able to do it for the jars in the plugin folder. I am using tomcat as web server. I was wondering if there any other options other than open all the BIRT projects in my workspace. Maybe using Eclipse User Libraries?
Re: attach sources to BIRT jars [message #557459 is a reply to message #557054] Tue, 07 September 2010 13:50 Go to previous message
The only way I have done this is to use the method described here:
http://confluence.sakaiproject.org/display/BOOT/Debugging+To mcat+Remotely+Using+Eclipse
I did open the source in the workspace (either check it out or download
the source from the download page). There may be a better way to do
this, but I have not done it.
Jason
Previous Topic:Column width Overflow
Next Topic: Connection profile store location
Current Time: Mon Jan 22 09:42:46 GMT 2018
Powered by FUDForum. Page generated in 0.01432 seconds
