Home » Eclipse Projects » BIRT » Binding parameters in dataset
Binding parameters in dataset [message #556929] Fri, 03 September 2010 04:30 Go to next message
mkrivic Missing name is currently offline mkrivic Missing name
Member
Is there any option to bind report parameters in dataset before dropping on report?
Example:
I have two datasets, and among the attributes, both have unique id type integer. so, I want to bind unique id from second dataset to unique id in first dataset before dropping on report design. I know I can do it with embedded tables on rpt design, but I need this before dropping on design.
Actually, my second dataset should collect unique id from first dataset.
[Updated on: Fri, 03 September 2010 04:30]
Report message to a moderator
Re: Binding parameters in scripted dataset [message #557033 is a reply to message #556929] Fri, 03 September 2010 12:35 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Will a joint data set not work in this case?
Jason
On 9/3/2010 4:30 AM, mkrivic wrote:
> on report? Example:
> design. Actually, my second dataset should collect unique id from first
> dataset.
Jason Weathersby
BIRT Exchange
Previous Topic:bubble charts
Next Topic:Get xpath from a selected column?
Current Time: Tue May 21 13:38:29 EDT 2013
Powered by FUDForum. Page generated in 0.02031 seconds
