Home » Modeling » Papyrus » [Papyrus Eclipse] Problems with checkout
[Papyrus Eclipse] Problems with checkout [message #556540] Wed, 01 September 2010 17:03 Go to next message
thalles  is currently offline thalles Friend
Hello
I'm new in this plugin development, so i followed the developers guide here http://wiki.eclipse.org/Papyrus_Developer_Guide#Retrieve_cod e and i'm getting an error with the source checkout using the psf file.
These are the errors :
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/developer/org.eclipse.papyrus.java.reverse .ui' failed.
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/uml/org.eclipse.papyrus.uml.feature' failed.
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/others/org.eclipse.papyrus.example.sashwin dows.simpleeditor' failed.
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/developer/org.eclipse.papyrus.java.reverse' failed.
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/uml/org.eclipse.papyrus.tabbedproperties.u ml' failed.
Checkout operation for ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/others/org.eclipse.papyrus.example.sashwin dows.fulleditor' failed.
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/developer/org.eclipse.papyrus.java.reverse .ui' doesn't exist
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/uml/org.eclipse.papyrus.uml.feature' doesn't exist
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/others/org.eclipse.papyrus.example.sashwin dows.simpleeditor' doesn't exist
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/developer/org.eclipse.papyrus.java.reverse' doesn't exist
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/uml/org.eclipse.papyrus.tabbedproperties.u ml' doesn't exist
svn: URL ' http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/trunk/plugins/others/org.eclipse.papyrus.example.sashwin dows.fulleditor' doesn't exist
Could someone help me please?
Thank you
Thalles Rodrigues
Re: [Papyrus Eclipse] Problems with checkout [message #557007 is a reply to message #556540] Fri, 03 September 2010 15:24 Go to previous messageGo to next message
Yann Tanguy is currently offline Yann TanguyFriend
Member
The psf file is probably not maintained. The source code you need is
located here:
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papy rus/branches/0.7.X/plugins
Checkout all plugins located in "core" "uml" and "others" folders. Not
that errors may be reported in
org.eclipse.papyrus.tabbedproperties.comments if EPF is not installed,
but you can ignore or close this project.
regards
YT
thalles a écrit :
> Hello
> failed.
> failed.
> failed.
> failed.
> failed.
> failed.
> svn: URL
> doesn't exist
> svn: URL
> doesn't exist
> svn: URL
> doesn't exist
> svn: URL
> doesn't exist
> svn: URL
> doesn't exist
> svn: URL
> doesn't exist
> Thank you
> Thalles Rodrigues
icon14.gif  Re: [Papyrus Eclipse] Problems with checkout [message #557318 is a reply to message #557007] Mon, 06 September 2010 16:27 Go to previous messageGo to next message
Thank you , now i can continue.
Re: [Papyrus Eclipse] Problems with checkout [message #607425 is a reply to message #557007] Mon, 06 September 2010 16:27 Go to previous message
Previous Topic:Confused about MDT Papyrus, Topcased and UML2
Next Topic:Model explorer and others
Current Time: Wed May 23 07:16:15 GMT 2018
Powered by FUDForum. Page generated in 0.01652 seconds
