| The minimum number of the libraries to run the BIRT? [message #555904] |
Mon, 30 August 2010 03:41  |
Missing name Missing name Messages: 55 Registered: July 2010 |
Member |
I'm planning to integrate the BIRT runtime to the production. I want only take the libraries which are necessary to run the BIRT.
Which are the libraries needed from the folder birt-runtime-2_6_0\ReportEngine\lib of the zip birt-runtime-2_6_0.zip to run the BIRT?
When I tested the BIRT with www.eclipse.org/birt/deploy/RunReport.java and XML datasource I used these libraries:
org.apache.commons.codec_1.3.0.v20100518-1140.jar
com.ibm.icu_4.2.1.v20100412.jar
engineapi.jar
js.jar
coreapi.jar
BR,
Mika
[Updated on: Mon, 30 August 2010 03:58] Report message to a moderator
| Re: The minimum number of the libraries to run the BIRT? [message #556066 is a reply to message #555960] |
Mon, 30 August 2010 13:13  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Mika,
It depends on what your reports will need. For example if you are not
using jdbc datasources those plugins can be removed. If you do not use
charting those plugins can be removed, etc. Right now the runtime
contains all the plugins that implement all runtime functions of BIRT.
Jason
On 8/30/2010 7:50 AM, mika.tapanainen@digia.com wrote:
> Hello,
> it seems that the program uses plugins dynamically from the ReportEngine
> folder.
> There is about 150 plugins or jar:s in the runtime BIRT. Are these all
> needed or is there smaller set of the plugins and jars needed?
> BR,
> Mika
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.08666 seconds
