| Different results in Preview vs PDF/HTML format [message #555482] |
Thu, 26 August 2010 14:01  |
No real name Messages: 1 Registered: August 2010 |
Junior Member |
Hello All,
I'm new to BIRT/Eclipse, I'm using build: 20100617-1415 and I have a problem that I am not sure how to go about resolving.
I have created a report and in "Preview" mode all the tables appear to be correctly formated and show relevant data. However, when I generate a PDF/HTML report, a couple of my tables get incorrect values and/or incorrect values and values print in duplicate/triplicate.
I'm not even sure where I should being to troubleshoot this, so any suggestions would be much appreciated,
Q
| Re: Different results in Preview vs PDF/HTML format [message #555671 is a reply to message #555482] |
Fri, 27 August 2010 10:16  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
In preview only a portion of the data is returned. Can you look at the
windows->preferences->Report Design->Preview->Data and check the no
limits of the number of rows to display option?
Jason
On 8/26/2010 2:01 PM, qwerty9119@hotmail.com wrote:
> Hello All,
> Q
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.03035 seconds
