Home » Eclipse Projects » BIRT » Increase column width in excel report
Increase column width in excel report [message #555466] Thu, 26 August 2010 13:00 Go to next message
Neil Wang is currently offline Neil Wang
I created an excel specific report which has a 10 column table. I set the width of each column to be 10% of the total width of the table (100%). The excel report that was generated shows the info successfully but the column width is very small. I tried changing the column width to 20% and the total width of the table to 200% and the result is still the same. Is there any way to increase column width in excel report? I understand that we can do it manually but I am looking for a solution that doesn't require us to do that.
please advise.
Neil
Re: Increase column width in excel report [message #555670 is a reply to message #555466] Fri, 27 August 2010 10:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Neil,
What version are you using? Also can you try setting it using point or
inches? Is the report set to fixed layout?
Jason
On 8/26/2010 1:00 PM, Neil Wang wrote:
> please advise.
> Neil
Jason Weathersby
BIRT Exchange
Re: Increase column width in excel report [message #555727 is a reply to message #555670] Fri, 27 August 2010 18:31 Go to previous messageGo to next message
I tried using point/inch but they don't work. The version I am using is 2.3.2 and the report is in auto layout.
please advise.
Neil
Re: Increase column width in excel report [message #556815 is a reply to message #555727] Thu, 02 September 2010 13:12 Go to previous messageGo to next message
any comment?
Re: Increase column width in excel report [message #556819 is a reply to message #556815] Thu, 02 September 2010 13:31 Go to previous messageGo to next message
Neil,
Sorry about the delay, I did not see your response. Did you try fixed
layout?
Jason
On 9/2/2010 1:12 PM, Neil Wang wrote:
> any comment?
Jason Weathersby
BIRT Exchange
Re: Increase column width in excel report [message #556833 is a reply to message #556819] Thu, 02 September 2010 14:07 Go to previous messageGo to next message
The outcome is still the same. Please advise.
Neil
Re: Increase column width in excel report [message #556850 is a reply to message #556833] Thu, 02 September 2010 15:28 Go to previous message
Neil,
I think this may have been fixed in later versions of birt. Take a look
at the attached example. In the second column I went into the advanced
properties to set the width of the data item, then I set the width of
the column. I exported to xls and the proper width showed up in xls.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">fixed layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where ordernumber = 10101</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="masterPage">Simple MasterPage</property>
<property name="width">7.5in</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="38">
<property name="width">1.1979166666666667in</property>
</column>
<column id="39">
<property name="width">0.20833333333333334in</property>
</column>
<column id="40">
<property name="width">1.53125in</property>
</column>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13"/>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property name="canShrink">true</property>
<property name="width">0.1in</property>
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
On 9/2/2010 2:07 PM, Neil Wang wrote:
> Neil
Jason Weathersby
BIRT Exchange
Previous Topic:BIRT Training Classes - Oct.
Next Topic:Aggregate always using Sum
Current Time: Wed May 22 04:13:27 EDT 2013
Powered by FUDForum. Page generated in 0.02030 seconds
