Home » Eclipse Projects » BIRT » Can't display Chart or Image in Excel export
icon4.gif  Can't display Chart or Image in Excel export [message #555326] Thu, 26 August 2010 10:30 Go to next message
YANG  is currently offline YANG Friend
Problem: When exporting report with charts or images inside to xls format, there's no display of charts or image in the result, just a blank form with the image size
it's working perfectly with HTML,PDF. But when I tested Excel export,
pictures are not displayed, and charts neither.
Please help me out.
Thanks in advance.
Re: Can't display Chart or Image in Excel export [message #555470 is a reply to message #555326] Thu, 26 August 2010 16:59 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
The excel emitter does not support images currently. take a look at
this blogpost for options.
http://birtworld.blogspot.com/2010/06/birt-excel-output.html
Jason
On 8/26/2010 6:30 AM, YANG wrote:
> Hi, Problem: When exporting report with charts or images inside to xls
> Please help me out.
> Thanks in advance.
Re: Can't display Chart or Image in Excel export [message #555481 is a reply to message #555470] Thu, 26 August 2010 17:57 Go to previous messageGo to next message
Thanks a lot for your reply.
Well, I've tried the Tribix Emitter and not satisfied with its export result in Excel: no respect for the Worksheet Rows and uses different font which I found not as good as BIRT's.
Do you know any other Emitter who does a perfect job?
Re: Can't display Chart or Image in Excel export [message #555669 is a reply to message #555481] Fri, 27 August 2010 14:08 Go to previous messageGo to next message
I do not know of any other open source xls emitters. I know there is a
bugzilla entry to add the chart to the BIRT xls emitter. Also Actuate
has a commercial emitter that is very good.
Jason
Re: Can't display Chart or Image in Excel export [message #555707 is a reply to message #555669] Fri, 27 August 2010 18:00 Go to previous messageGo to next message
Thanks again for your reply.
I've tested the Actuate BIRT Report Designer Pro. It does work fine.
But if I purchase it, how can I use its emitters in any standalone Java application.
Like the BIRT open source Eclipse plugin, it has its own Runtime engine librabies, but when it comes to the Actuate BIRT, they kinda use a different prototype for the Excel Emitter, so when I try to use it as the same way as Tribix Emiitter, there are exceptions.
Did I forget sth important or there is another proper way to combine Actuate BIRT and Eclipse?
Re: Can't display Chart or Image in Excel export [message #556080 is a reply to message #555707] Mon, 30 August 2010 17:44 Go to previous messageGo to next message
I believe you can a commercial version of the engine, but I think you
will have to contact Actuate:
http://www.birt-exchange.com/be/news-events/contact-us/
Also remember that this is available in Actuate 11 which is releasing in
September.
Jason
> application.
Re: Can't display Chart or Image in Excel export [message #556084 is a reply to message #556080] Mon, 30 August 2010 18:08 Go to previous message
Thank you, I will get contact with Actuate.
Previous Topic:Error when exporting Runnable JAR with BIRT
Next Topic:Automatically generating a queryText for a xml dataset?
Current Time: Sun Apr 22 16:24:29 GMT 2018
Powered by FUDForum. Page generated in 0.02182 seconds
