| Read parameters (column mappings) from a dataSet using the API`?? [message #555128] |
Wed, 25 August 2010 10:06  |
Originally posted by: vm.vm.com
I have a .rptdesign with a working dataset connected to a xml datasource
containing a bunch of parameters. I would like to read those parameters
using the birt api. Here is what I do:
List<String> parameters = new ArrayList<String>();
OdaDataSetHandle de = (OdaDataSetHandle) ds;
CachedMetaDataHandle cachedMeta = de.getCachedMetaDataHandle();
List<?> cols = (List<?>) cachedMeta.getResultSet().getValue();
for (int i = 0; i < cols.size(); i++) {
ResultSetColumn rsc = (ResultSetColumn) cols.get(i);
String name = rsc.getColumnName();
parameters.add(name);
this works fine if the .rptdesign file has already been used (eg. added some
tables and added some parameters).
But if I load a .rptdesign file which has no content on the master page the
above line:
fails with a NullPointerException. I guess this is because the data has not
been cached jet. But how do I read data set parameters from a .rptdesign
file which has no other content or has not been run jet?
| Re: Read parameters (column mappings) from a dataSet using the API`?? [message #555319 is a reply to message #555196] |
Thu, 26 August 2010 05:33   |
I now do:
public List<String> readAllParameters(DataSetHandle ds) {
System.out.println(ds.getProperty("queryText"));
PropertyHandle pp = ds.getPropertyHandle(DataSetHandle.PARAMETERS_PROP);
OdaDataSetParameter pl_1 = (OdaDataSetParameter) pp.get(0);
String myparmname = pl_1.getName();
String myparmdefaultvalue = pl_1.getDefaultValue();
but the line:
gives a NullPointerException even though the querytext on the dataset is
valid and contains (from the above print statement):
table0#-TNAME-#table0#:#[/root/parameters]#:#{box;STRING;/pa rameter[@id= "box"]/@value},{length;STRING;/parameter[@id="length"]/@value}
any ideas?
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:i53p91$hi2$1@build.eclipse.org...
> If you want the design for the dataset parameter use script similar to
> this:
> var pl =
> reportContext.getDesignHandle().getDataSets().get(0).getProp ertyHandle( "parameters");
> //first ds parameter OdaDataSetParameter
> var pl_1 = pl.get(0);
> You use the api like
> PropertyHandle phl
> =dsHandle.getPropertyHandle(DataSetHandle.PARAMETERS_PROP );
> OdaDataSetParameter prm1 = (OdaDataSetParameter)phl.get(0);
> prm1.getName();
> Jason
>> some tables and added some parameters).
>> the above line:
>> not been cached jet. But how do I read data set parameters from a
>> .rptdesign file which has no other content or has not been run jet?
| Re: Read parameters (column mappings) from a dataSet using the API`?? [message #555487 is a reply to message #555469] |
Thu, 26 August 2010 13:51   |
I don't use that syntax or any scripts for that matter, but maybe thats
necessary to be able to read parameters from a "unused" .rptdesign file?
news:i566cf$8d9$1@build.eclipse.org...
> I do not see the dataset parmeter syntax in your table line "{?p1?}". Take
> a look at the attached example:
> It uses this xml:
> <?xml version="1.0"?>
> <BookStore xmlns="http://www.books.org"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" >
> <Book category="my first cat">
> <Title>Illusions The Adventures of a Reluctant
> Messiah</Title>
> <Author>Richard Bach</Author>
> <Date>1977</Date>
> <ISBN>0-440-34319-4</ISBN>
> <Publisher>Dell Publishing Co.</Publisher>
> </Book>
> <Book category="my second cat">
> <Title>The First and Last Freedom</Title>
> <Author>J. Krishnamurti</Author>
> <Date>1954</Date>
> <ISBN>0-06-064831-7</ISBN>
> <Publisher>Harper & Row</Publisher>
> </Book>
> </BookStore>
> Jason
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version
> 2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
> <property name="units">in</property>
> <method name="initialize"><![CDATA[var pl =
> myparmdefaultvalue = pl_1.getDefaultValue();]]></method>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <property name="imageDPI">96</property>
> <data-sources>
> <oda-data-source
> extensionID="org.eclipse.datatools.enablement.oda.xml" name="Data Source"
> id="7">
> <text-property name="displayName"></text-property>
> <property
> name="FILELIST">C:\work\styles\BookStore.xml</property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet " name="Data
> Set" id="8">
> <list-property name="parameters">
> <structure>
> <property name="name">p1</property>
> <property name="nativeName">p1</property>
> <property name="dataType">string</property>
> <property name="nativeDataType">12</property>
> <property name="position">1</property>
> <expression name="defaultValue" type="constant">my
> first cat</expression>
> <property name="isOptional">false</property>
> <property name="isInput">true</property>
> <property name="isOutput">false</property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> <property name="name">Title</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">Author</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">category</property>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">Data Source</property>
> <structure>
> <property name="nativeName">Title</property>
> </structure>
> <structure>
> <property name="nativeName">Author</property>
> </structure>
> <structure>
> <property name="nativeName">category</property>
> </structure>
> </list-property>
> <xml-property
> name="queryText"><![CDATA[table0#-TNAME-#table0#:#[/BookStore/Book[@category= "{?p1?}" ]]#:#{Title;STRING;/Title},{Author;STRING;/Author},{category ;STRING;/@category}#:# <"","http:%%www.books.org";"xsi","http:%%www.w3.org%2001%XMLSchema-instance ">]]></xml-property>
> <xml-property name="designerValues"><![CDATA[<?xml
> version="1.0" encoding="UTF-8"?>
> <model:DesignValues
> xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
> xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
> <Version>1.0</Version>
> <design:DataSetParameters>
> <design:parameterDefinitions>
> <design:inOutMode>In</design:inOutMode>
> <design:attributes>
> <design:name>p1</design:name>
> <design:position>1</design:position>
> <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
> <design:precision>-1</design:precision>
> <design:scale>-1</design:scale>
> <design:nullability>Unknown</design:nullability>
> </design:attributes>
> </design:parameterDefinitions>
> </design:DataSetParameters>
> <design:ResultSets derivedMetaData="true">
> <design:resultSetDefinitions>
> <design:resultSetColumns>
> <design:resultColumnDefinitions>
> <design:attributes>
> <design:name>Title</design:name>
> <design:usageHints>
> <design:label>Title</design:label>
> <design:formattingHints/>
> </design:usageHints>
> </design:resultColumnDefinitions>
> <design:attributes>
> <design:name>Author</design:name>
> <design:position>2</design:position>
> <design:usageHints>
> <design:label>Author</design:label>
> <design:attributes>
> <design:name>category</design:name>
> <design:position>3</design:position>
> <design:usageHints>
> <design:label>category</design:label>
> </design:resultSetColumns>
> <design:criteria/>
> </design:resultSetDefinitions>
> </design:ResultSets>
> </model:DesignValues>]]></xml-property>
> <list-property name="privateDriverProperties">
> <ex-property>
> <name>MAX_ROW</name>
> <value>-1</value>
> </ex-property>
> <ex-property>
> <name>XML_FILE</name>
> </ex-property>
> </list-property>
> </oda-data-set>
> </data-sets>
> <styles>
> <style name="report" id="4">
> <property name="fontFamily">sans-serif</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab-cell" id="5">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="6">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <data id="31">
> <list-property name="boundDataColumns">
> <structure>
> <property name="name">Column Binding</property>
> <expression name="expression"
> type="javascript">myparmdefaultvalue;</expression>
> </structure>
> </list-property>
> <property name="resultSetColumn">Column Binding</property>
> </data>
> <table id="9">
> <property name="dataSet">Data Set</property>
> <structure>
> <text-property
> name="displayName">Title</text-property>
> type="javascript">dataSetRow["Title"]</expression>
> </structure>
> <structure>
> <text-property
> name="displayName">Author</text-property>
> type="javascript">dataSetRow["Author"]</expression>
> </structure>
> <structure>
> <text-property
> name="displayName">category</text-property>
> type="javascript">dataSetRow["category"]</expression>
> </structure>
> </list-property>
> <column id="28"/>
> <column id="29"/>
> <column id="30"/>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> <text-property
> name="text">Title</text-property>
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property
> name="text">Author</text-property>
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property
> name="text">category</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="17">
> <cell id="18">
> <data id="19">
> <property
> name="resultSetColumn">Title</property>
> </data>
> </cell>
> <cell id="20">
> <data id="21">
> <property
> name="resultSetColumn">Author</property>
> </data>
> </cell>
> <cell id="22">
> <data id="23">
> <property
> name="resultSetColumn">category</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="24">
> <cell id="25"/>
> <cell id="26"/>
> <cell id="27"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
> On 8/26/2010 5:33 AM, vm wrote:
>> I now do:
>> but the line:
>> any ideas?
>>> this:
>>> var pl =
>>> PropertyHandle phl
>>> prm1.getName();
>>> Jason
>>>> datasource
>>>> the above line:
| Re: Read parameters (column mappings) from a dataSet using the API`?? [message #555655 is a reply to message #555487] |
Fri, 27 August 2010 10:00   |
Jason Weathersby Messages: 9167 Registered: July 2009 |
From the api try:
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
ReportDesignHandle design = null;
try{
design = session.openDesign("Reports/XMLParameter.rptdesign" );
OdaDataSetHandle dsh = (OdaDataSetHandle) design.getDataSets().get(0);
PropertyHandle phl
=dsh.getPropertyHandle(DataSetHandle.PARAMETERS_PROP );
OdaDataSetParameterHandle prm1 =
(OdaDataSetParameterHandle)phl.get(0);
System.out.println(prm1.getName());
System.out.println(prm1.getDefaultValue());
Jason
>> Take a look at the attached example:
>> It uses this xml:
>> <Title>Illusions The Adventures of a Reluctant Messiah</Title>
>> <Date>1977</Date>
>> </Book>
>> <Date>1954</Date>
>> </Book>
>> </BookStore>
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
>> version="3.2.21" id="1">
>> <data-sources>
>> <oda-data-source
>> Source" id="7">
>> <property name="FILELIST">C:\work\styles\BookStore.xml</property>
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <oda-data-set
>> name="Data Set" id="8">
>> <structure>
>> <expression name="defaultValue" type="constant">my first cat</expression>
>> </structure>
>> </list-property>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> <xml-property
>> <xml-property name="designerValues"><![CDATA[<?xml version="1.0"
>> encoding="UTF-8"?>
>> <model:DesignValues
>> xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
>> <design:attributes>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:attributes>
>> <design:usageHints>
>> <design:criteria/>
>> <ex-property>
>> <value>-1</value>
>> </ex-property>
>> <ex-property>
>> </ex-property>
>> </list-property>
>> </oda-data-set>
>> </data-sets>
>> <styles>
>> </style>
>> </style>
>> </style>
>> </styles>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <data id="31">
>> <structure>
>> </structure>
>> </list-property>
>> </data>
>> <table id="9">
>> <structure>
>> <text-property name="displayName">Title</text-property>
>> </structure>
>> <structure>
>> <text-property name="displayName">Author</text-property>
>> </structure>
>> <structure>
>> <text-property name="displayName">category</text-property>
>> </structure>
>> </list-property>
>> <column id="28"/>
>> <column id="29"/>
>> <column id="30"/>
>> <header>
>> <row id="10">
>> <cell id="11">
>> <label id="12">
>> <text-property name="text">Title</text-property>
>> </label>
>> </cell>
>> <cell id="13">
>> <label id="14">
>> <text-property name="text">Author</text-property>
>> </label>
>> </cell>
>> <cell id="15">
>> <label id="16">
>> <text-property name="text">category</text-property>
>> </label>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="17">
>> <cell id="18">
>> <data id="19">
>> <property name="resultSetColumn">Title</property>
>> </data>
>> </cell>
>> <cell id="20">
>> <data id="21">
>> <property name="resultSetColumn">Author</property>
>> </data>
>> </cell>
>> <cell id="22">
>> <data id="23">
>> <property name="resultSetColumn">category</property>
>> </data>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="24">
>> <cell id="25"/>
>> <cell id="26"/>
>> <cell id="27"/>
>> </row>
>> </footer>
>> </table>
>> </body>
>> </report>
>>> I now do:
>>> but the line:
>>> any ideas?
>>>> this:
>>>> var pl =
>>>> PropertyHandle phl
>>>> prm1.getName();
>>>> Jason
>>>>> datasource
>>>>> parameters
>>>>> added
>>>>> page
>>>>> the above line:
>>>>> has
Jason Weathersby
BIRT Exchange
| Re: Read parameters (column mappings) from a dataSet using the API`?? [message #556662 is a reply to message #555655] |
Thu, 02 September 2010 05:12   |
Same problem. Currently its only possible to read the parameters from a data
set if they have been bound to a table in the .rptdesign file.
news:i58gah$m93$1@build.eclipse.org...
> From the api try:
> try{
> PropertyHandle phl
> Jason
>>> It uses this xml:
>>> <Date>1977</Date>
>>> </Book>
>>> <Date>1954</Date>
>>> </Book>
>>> </BookStore>
>>> Jason
>>> <data-sources>
>>> <oda-data-source
>>> Source" id="7">
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <oda-data-set
>>> <structure>
>>> cat</expression>
>>> </structure>
>>> </list-property>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <xml-property
>>> encoding="UTF-8"?>
>>> <model:DesignValues
>>> <design:attributes>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:attributes>
>>> <design:usageHints>
>>> <design:criteria/>
>>> <ex-property>
>>> <value>-1</value>
>>> </ex-property>
>>> <ex-property>
>>> </ex-property>
>>> </list-property>
>>> </oda-data-set>
>>> </data-sets>
>>> <styles>
>>> </style>
>>> </style>
>>> </style>
>>> </styles>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <data id="31">
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </data>
>>> <table id="9">
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> <column id="28"/>
>>> <column id="29"/>
>>> <column id="30"/>
>>> <header>
>>> <row id="10">
>>> <cell id="11">
>>> <label id="12">
>>> </label>
>>> </cell>
>>> <cell id="13">
>>> <label id="14">
>>> </label>
>>> </cell>
>>> <cell id="15">
>>> <label id="16">
>>> </label>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="17">
>>> <cell id="18">
>>> <data id="19">
>>> </data>
>>> </cell>
>>> <cell id="20">
>>> <data id="21">
>>> </data>
>>> </cell>
>>> <cell id="22">
>>> <data id="23">
>>> </data>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="24">
>>> <cell id="25"/>
>>> <cell id="26"/>
>>> <cell id="27"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </body>
>>> </report>
>>>> I now do:
>>>> PropertyHandle pp =
>>>> but the line:
>>>> is
>>>> any ideas?
>>>>> this:
>>>>> var pl =
>>>>> PropertyHandle phl
>>>>> prm1.getName();
>>>>> Jason
>>>>>> datasource
>>>>>> parameters
>>>>>> added
>>>>>> page
>>>>>> the above line:
>>>>>> has
| Re: Read parameters (column mappings) from a dataSet using the API`?? [message #556784 is a reply to message #556662] |
Thu, 02 September 2010 11:14  |
Is your parameter dynamic? Can you post the snippet of xml that shows
your data parameter? I ran this test with 2.5.2 and it worked fine.
Jason
> data set if they have been bound to a table in the .rptdesign file.
>> From the api try:
>> try{
>> PropertyHandle phl
>> OdaDataSetParameterHandle prm1 = (OdaDataSetParameterHandle)phl.get(0);
>> Jason
>>>> It uses this xml:
>>>> <Date>1977</Date>
>>>> </Book>
>>>> <Date>1954</Date>
>>>> </Book>
>>>> </BookStore>
>>>> Jason
>>>> <data-sources>
>>>> <oda-data-source
>>>> Source" id="7">
>>>> </oda-data-source>
>>>> </data-sources>
>>>> <data-sets>
>>>> <oda-data-set
>>>> <structure>
>>>> cat</expression>
>>>> </structure>
>>>> </list-property>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <xml-property
>>>> encoding="UTF-8"?>
>>>> <model:DesignValues
>>>> <design:attributes>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:attributes>
>>>> <design:usageHints>
>>>> <design:criteria/>
>>>> <ex-property>
>>>> <value>-1</value>
>>>> </ex-property>
>>>> <ex-property>
>>>> </ex-property>
>>>> </list-property>
>>>> </oda-data-set>
>>>> </data-sets>
>>>> <styles>
>>>> </style>
>>>> </style>
>>>> </style>
>>>> </styles>
>>>> <page-setup>
>>>> <page-footer>
>>>> <text id="3">
>>>> </text>
>>>> </page-footer>
>>>> </page-setup>
>>>> <body>
>>>> <data id="31">
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> </data>
>>>> <table id="9">
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> <structure>
>>>> </structure>
>>>> </list-property>
>>>> <column id="28"/>
>>>> <column id="29"/>
>>>> <column id="30"/>
>>>> <header>
>>>> <row id="10">
>>>> <cell id="11">
>>>> <label id="12">
>>>> </label>
>>>> </cell>
>>>> <cell id="13">
>>>> <label id="14">
>>>> </label>
>>>> </cell>
>>>> <cell id="15">
>>>> <label id="16">
>>>> </label>
>>>> </cell>
>>>> </row>
>>>> </header>
>>>> <detail>
>>>> <row id="17">
>>>> <cell id="18">
>>>> <data id="19">
>>>> </data>
>>>> </cell>
>>>> <cell id="20">
>>>> <data id="21">
>>>> </data>
>>>> </cell>
>>>> <cell id="22">
>>>> <data id="23">
>>>> </data>
>>>> </cell>
>>>> </row>
>>>> </detail>
>>>> <footer>
>>>> <row id="24">
>>>> <cell id="25"/>
>>>> <cell id="26"/>
>>>> <cell id="27"/>
>>>> </row>
>>>> </footer>
>>>> </table>
>>>> </body>
>>>> </report>
>>>>> I now do:
>>>>> PropertyHandle pp =
>>>>> but the line:
>>>>> dataset is
>>>>> any ideas?
>>>>>> similar to
>>>>>> this:
>>>>>> var pl =
>>>>>> PropertyHandle phl
>>>>>> prm1.getName();
>>>>>> Jason
>>>>>>> datasource
>>>>>>> parameters
>>>>>>> added
>>>>>>> page
>>>>>>> the above line:
>>>>>>> has
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.02047 seconds
