Home » Eclipse Projects » Subversive » Subversive unusable, fails with "Unable to locate login configuration"
Subversive unusable, fails with "Unable to locate login configuration" [message #554618] Mon, 23 August 2010 17:33 Go to next message
Reynald Borer is currently offline Reynald BorerFriend
Hi everyone,
I am experiencing a very annoying issue with Subversive latest version running on Eclipse Helios. Basically, the plugin is not usable anymore. It asks for my secure storage password, and then each time fails with this error message: "java.lang.SecurityException: Unable to locate a login configuration".
I have already tried to tweak my JRE location (version 1.6.0_20), change security parameters like java.security.auth.login.config, but still the same issue is happening.
Could someone help me about this point ? This is very annoying.
My environment:
- Linux (Fedora 13)
- JRE version 1.6.0_20
- Eclipse Helios with subversive 0.7.9
Thanks in advance for your help.
Reynald
Re: Subversive unusable, fails with "Unable to locate login configuration" [message #554621 is a reply to message #554618] Mon, 23 August 2010 17:50 Go to previous message
I reported a bug about this, if anyone is interested in the Java stacktrace: https://bugs.eclipse.org/bugs/show_bug.cgi?id=323418
Previous Topic:SVN authentication issue
Next Topic:"Collecting Resources" on Team Update takes forever
Current Time: Sun May 20 12:20:35 GMT 2018
Powered by FUDForum. Page generated in 0.01985 seconds
