Home » Eclipse Projects » BIRT » Is it possible to bold a word in the text box of the PDF report
Is it possible to bold a word in the text box of the PDF report [message #553868] Thu, 19 August 2010 09:02 Go to next message
Mika Tapanainen is currently offline Mika TapanainenFriend
Member
Is it possible to bold a single word in the text box of the PDF report? Or do other formatting.
In the HTML reports that is possible with tags.
BR,
Mika
Re: Is it possible to bold a word in the text box of the PDF report [message #553991 is a reply to message #553868] Thu, 19 August 2010 15:18 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
If you use a text element something like this should work:
Use this expression
this is a test of the <b>bold</b> text element
Make sure to set the type to HTML and not Auto.
Jason
On 8/19/2010 5:02 AM, mika.tapanainen@digia.com wrote:
> Hello,
> BR,
> Mika
Re: Is it possible to bold a word in the text box of the PDF report [message #554083 is a reply to message #553991] Fri, 20 August 2010 06:19 Go to previous messageGo to next message
Member
Is this working in the PDF file? I have tested and in the pdf file I can see only the <b> tags, but not a bold word..
Re: Is it possible to bold a word in the text box of the PDF report [message #554089 is a reply to message #554083] Fri, 20 August 2010 07:13 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
normally it should work for text elements. As Jason already said
'Make sure to set the type to HTML and not Auto.'
At the top of the edit text item window you can set the type value.
Re: Is it possible to bold a word in the text box of the PDF report [message #554123 is a reply to message #554089] Fri, 20 August 2010 09:04 Go to previous message
Member
I'm sorry I didn't use html..
Thanks, now it is working
Previous Topic:Editing Birt xls prototype emitter
Next Topic:The single word font size change is not working?
Current Time: Tue Feb 20 04:30:34 GMT 2018
Powered by FUDForum. Page generated in 0.01553 seconds
