Home » Eclipse Projects » BIRT » texte and data in the same line
texte and data in the same line [message #553436] Tue, 17 August 2010 14:08 Go to next message
zaim  is currently offline zaim Friend
hi everybody ,
i want to insert a data near a text without using grid ,
function : data
thanks and sorry for my bad english
Re: texte and data in the same line [message #553472 is a reply to message #553436] Tue, 17 August 2010 15:57 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
Use a Dynamic Text element and build your output string inside that.
Re: texte and data in the same line [message #553498 is a reply to message #553436] Tue, 17 August 2010 17:09 Go to previous messageGo to next message
Steve Schafer is currently offline Steve SchaferFriend
In the advanced properties for each of the two controls, set Section -> Display to Inline
Re: texte and data in the same line [message #553712 is a reply to message #553472] Wed, 18 August 2010 14:55 Go to previous messageGo to next message
thanks for response ,
but i dont find a data inside ,
i find just " native javascript functions , mathematic functions ....." ,
i want to find a data source to select my columns .
Re: texte and data in the same line [message #553721 is a reply to message #553712] Wed, 18 August 2010 15:23 Go to previous message
No real name is currently offline No real nameFriend
try to bind your dataset to the dynamic text element.
Select the dynamic text element, open the property editor view and
choose the binding tab. There you can set a dataset and after you done
this you hopefully can select your dataset.
Previous Topic:War File Export not available in BIRT 2.6.1 runtime
Next Topic:BIRT NYC Party
Current Time: Mon May 21 05:29:13 GMT 2018
Powered by FUDForum. Page generated in 0.02253 seconds
