But now i reached a point where i have some problems with the structure
of my report. In my EMF Model i have a list of items and when i create a
DataSet with an OCL query which gets the data out of the list and stores
it into a table in my report the elements aren't sorted anymore. So the
entries in the table aren't in the same order like they are in my array
list. I want to create a table where the first column should have an ID
and this ID can be the list entries position and afterwards i could sort
my table ascending for this attribute but how can i get the position? Or
is there another possibility to get my list in an ordered way?
Besides i have the following problem. I created a class in my EMF Model
and two subclasses inherit from it. Now i want to create a DataSet for a
table in which all three classes may be inserted. So i need somekind
instanceof check?! Any ideas?
Any chance you could take a screenshot of the problem, ie the table and
explain what you need? email it to me at jasonweathersby at windstream
dot net.
Jason
n 8/17/2010 3:35 AM, bora kiliclar wrote:
> i want to use an EMF Model as a DataSource for my Report. I followed
> http://timezra.blogspot.com/2008/04/oda-ecore-getting-starte d-guide.html
> and it worked fine for me. I can create a report using my EMF model as a
> DataSource and adding DataSets to my report.
> Thanks in advance.
