Home » Eclipse Projects » BIRT » Multiple tomcats using single birt runtime
Multiple tomcats using single birt runtime [message #553061] Mon, 16 August 2010 09:53
john mcteague is currently offline john mcteagueFriend
Has anyone any experience using a single birt home within an application spread across multiple tomcat instances?
The BIRT runtime is currently located in a common directory on the server and each instance of the application has a config parameter to locate the birt home (using PlatformFileContext).
We currently see no problems at runtime with this setup, but load isnt particularly high. Are there any known issues running in this configuration under high load?
I appreciate the alternative is to place the birt runtime inside the war and use PlatformServletContext, thereby ensuring each instance of the app has its own birt runtime.
Previous Topic:Table breaking with very large data
Next Topic:how to call a report from a button in java???
Current Time: Tue Apr 24 05:11:32 GMT 2018
Powered by FUDForum. Page generated in 0.06460 seconds
