Home » Eclipse Projects » BIRT » Birt 2.6.0 Viewer in RCP Application
Birt 2.6.0 Viewer in RCP Application [message #552868] Fri, 13 August 2010 18:19 Go to next message
Mike  is currently offline Mike
I'm trying to move from Eclipse 3.4.2 / Birt 2.3.2 to Eclipse 3.6.0 / Birt 2.6.0. I have run into a snag when I attempt to use the viewer in my RCP application.
My install is a clean Eclipse 3.6.0 with Birt 2.6.0 install using the update site. I created a new workspace and imported all of my code. I brought the report designs into the designer and it converted them to the new version format. I did some rudimentary tests in the Report Perspective.
My app has a ReportView that extends ViewPart. This is where I run and render the report. All of my code is unchanged. Only the Eclipse and Birt plugins have. When I invoke run() method of IRunAndRenderTask, I get an EngineException. Stack trace below. I'm wondering if anyone else has seen anything like this. I found this, https://bugs.eclipse.org/bugs/show_bug.cgi?id=292109 , which seems to apply, but I can't find out what is causing the BirtException. Any ideas?
Aug 13, 2010 3:01:36 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: null
org.eclipse.birt.report.engine.api.EngineException
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:158)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:53)
at org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesig n(EngineTask.java:1637)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:95)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
at com.zhone.rtl.tpm.rcp.views.ReportView.previewReport(ReportV iew.java:194)
at com.zhone.rtl.tpm.rcp.views.ReportView.createPartControl(Rep ortView.java:65)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:1071)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.j ava:3822)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:3819)
at com.zhone.rtl.tpm.rcp.command.handlers.ReportViewHandler.exe cute(ReportViewHandler.java:96)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3552)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3171)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.zhone.rtl.tpm.rcp.Application.start(Application.java:25)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: org.eclipse.birt.core.exception.BirtException
at org.eclipse.birt.core.script.ScriptContext.getScriptEngine(S criptContext.java:225)
at org.eclipse.birt.core.script.ScriptContext.compile(ScriptCon text.java:145)
at org.eclipse.birt.report.engine.executor.ExecutionContext.com pile(ExecutionContext.java:736)
at org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:670)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScriptInternal(ScriptExecutor.java:61)
at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleScript(ScriptExecutor.java:48)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleInitialize(ReportScriptExecutor.java:44)
... 47 more
Aug 13, 2010 3:01:37 PM org.eclipse.birt.report.engine.script.internal.ScriptExecuto r addException
WARNING: null
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:82)
at org.eclipse.birt.report.engine.api.impl.EngineTask.startFact ory(EngineTask.java:1669)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:97)
at org.eclipse.birt.report.engine.script.internal.ReportScriptE xecutor.handleBeforeFactory(ReportScriptExecutor.java:74)
... 47 more
org.eclipse.birt.report.engine.api.EngineException: cant create data engine
at org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:848)
at org.eclipse.birt.report.engine.executor.ExecutionContext.get DataEngine(ExecutionContext.java:860)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:124)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportExecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplciateReportExecutor.execute(SuppressDuplciateReportExec utor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportExecutor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:170)
at org.eclipse.birt.report.engine.adapter.ModelDteApiAdapter.<init >(ModelDteApiAdapter.java:176)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.<init >(AbstractDataEngine.java:107)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.<init >(DteDataEngine.java:85)
at org.eclipse.birt.report.engine.data.DataEngineFactory.create DataEngine(DataEngineFactory.java:100)
at org.eclipse.birt.report.engine.executor.ExecutionContext.ope nDataEngine(ExecutionContext.java:843)
... 52 more
Re: Birt 2.6.0 Viewer in RCP Application [message #552881 is a reply to message #552868] Fri, 13 August 2010 20:49 Go to previous messageGo to next message
I bit the bullet and grabbed the Birt source and hooked it up to my app so I could see what the actual BirtException was being gobbled by https://bugs.eclipse.org/bugs/show_bug.cgi?id=292109 .
Let me just say after a whole bunch of messing around it turns out that at some point (Birt 2.5.1??) I need to include the org.eclipse.birt.report.engine.script.javascript plugin in my configuration since I'm using scripted data sources. Its probably in the docs some place. Laughing
The report is now running and being rendered. It goes into a file for some reason, but it does work.
Re: Birt 2.6.0 Viewer in RCP Application [message #553148 is a reply to message #552881] Mon, 16 August 2010 10:38 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Mike,
What do you mean by it goes into a file?
Jason
> docs some place. :lol:
Jason Weathersby
BIRT Exchange
Re: Birt 2.6.0 Viewer in RCP Application [message #553285 is a reply to message #553148] Mon, 16 August 2010 20:53 Go to previous messageGo to next message
Jason,
I'm emitting a pdf to a temporary file created using File.createTempFile(). Once the task is finished generating the file I want to open it in a SWT Browser in a view via:
browser.setUrl( options.getOutputFileName() );
In Windows, this displays the report in a browser window in the RCP app. In Linux, the view is created, but not the browser and I get a file dialog asking where I want to save the file.
Until recently, all of development and targets have been for windows. Now I'm doing my development using Linux and also targeting Linux as a runtime environment. Its probably something stupid or a bug.
I'm also thinking that Linux might not like File and would rather have something resembles an actual URI. I'm going to look into that now.
If you have any ideas, I would appreciate it.
Re: Birt 2.6.0 Viewer in RCP Application [message #553286 is a reply to message #553285] Mon, 16 August 2010 21:01 Go to previous messageGo to next message
I knew I was stupid. I don't have an Acrobat reader in the Linux Firefox. All PDF files are opened in an external Document Viewer. I'm going to look into getting that installed and working.
Re: Birt 2.6.0 Viewer in RCP Application [message #553530 is a reply to message #553286] Tue, 17 August 2010 16:08 Go to previous messageGo to next message
Let us know how it goes.
Jason Weathersby
BIRT Exchange
Re: Birt 2.6.0 Viewer in RCP Application [message #558451 is a reply to message #552881] Sun, 12 September 2010 19:59 Go to previous message
Marco Lopes is currently offline Marco Lopes
Member
We had the same problem with our RCP app. Solved that one years ago.
Here is the code Smile
PDF_PRINT_JAVASCRIPT = "this.print({bUI: true, bSilent:false});\r";
String tempFile = ... create temp file...
FileOutputStream out = new FileOutputStream(tempFile);
FileInputStream in = new FileInputStream(filename);
PdfReader pdfReader = new PdfReader(in);
PdfStamper pdfStamper = new PdfStamper(pdfReader,out);
pdfStamper.addJavaScript(BirtVARS.PDF_PRINT_JAVASCRIPT);
pdfStamper.close();
We are using iText-5.0.4.jar
[Updated on: Sun, 12 September 2010 20:04]
Report message to a moderator
Previous Topic:delete
Next Topic:Yellowfin releases fact sheet on In-memory analysis
Current Time: Thu Jun 20 01:11:52 EDT 2013
Powered by FUDForum. Page generated in 0.03543 seconds
