Home » Eclipse Projects » BIRT » how to call a report from a button in java???
how to call a report from a button in java??? [message #552806] Fri, 13 August 2010 15:17 Go to next message
No real name is currently offline No real nameFriend
I designe my report but i couldn´t find how to call it from a button in java. Anyone know how to do it?????
Re: how to call a report from a button in java??? [message #552835 is a reply to message #552806] Fri, 13 August 2010 16:52 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
How do you want to display it? Are you using the APIs?
Re: how to call a report from a button in java??? [message #552839 is a reply to message #552835] Fri, 13 August 2010 16:53 Go to previous messageGo to next message
See this post for a swing example:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg27568. html
Re: how to call a report from a button in java??? [message #552882 is a reply to message #552806] Sat, 14 August 2010 01:17 Go to previous messageGo to next message
thank´s for your answear. i will reed it and test it in my project.
Re: how to call a report from a button in java??? [message #552914 is a reply to message #552806] Sat, 14 August 2010 12:55 Go to previous messageGo to next message
I test the example and it doesn´t work. I change the directory path and make a new report. It run, but the code didn´t show my report.
I don´t know why Eclipse make a software that doesn´t work. That you can´t integrate with SDK and the SWING aplication that we develope???
I will try to see if a could make it work the report, but it´s a pice of crap.
Re: how to call a report from a button in java??? [message #553147 is a reply to message #552914] Mon, 16 August 2010 14:07 Go to previous message
Can you post the error you are getting?
Did you set the BIRT_HOME to the report engine directory?
You may also want to look at this example:
http://www.birt-exchange.org/org/devshare/deploying-birt-rep orts/1182-birt-report-from-java-swing/
Jason
> crap.
Previous Topic:Multiple tomcats using single birt runtime
Next Topic:Table breaking with very large data
Current Time: Sat Feb 24 01:02:40 GMT 2018
Powered by FUDForum. Page generated in 0.01783 seconds
