Home » Eclipse Projects » BIRT » BirtViewer and the Jazz Data Source(It doesn't work)
BirtViewer and the Jazz Data Source [message #552768] Fri, 13 August 2010 13:12 Go to next message
Krzysiek  is currently offline Krzysiek Friend
I made a report using Birt 2.3.2 and I took data directly from RTC by Jazz Data Source.
I've deployed BirtViewer 2.6 Runtime in Tomcat 5.5. The example reports and any others (which use JDBC data source) are working correctly, but the report with Jazz Data Source throw and Exceptions
(below)
My question: What should I do to make it work ? Is it possible at all to (are reports with Jazz Data Source supported by BirtViewer ) ?
Krzysiek
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details:
Cannot find or process the com.ibm.team.reports.generic.dataSource driver's data source extension configuration.
Cannot find the ODA dataSource extension (com.ibm.team.reports.generic.dataSource).
Check the workspace log file for any problems with loading the extension bundle and its dependencies.
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:70)
at org.eclipse.birt.report.engine.executor.ExtendedItemExecutor .execute(ExtendedItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
at org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:41)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:258)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:252)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
at org.eclipse.birt.report.service.ReportEngineService.runRepor t(ReportEngineService.java:1307)
at org.eclipse.birt.report.service.BirtViewerReportService.runR eport(BirtViewerReportService.java:158)
at org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(BirtRunReportActionHandler.java:81)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:48)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:600)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:647)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:215)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11Ap rProcessor.java:843)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionH andler.process(Http11AprProtocol.java:640)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoin t.java:1293)
at java.lang.Thread.run(Thread.java:736)
Caused by: org.eclipse.birt.report.data.adapter.api.AdapterException: An exception occurred during processing. Please see the following message for details:
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:623)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:74)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.executeQueries(ExtendedGenerateExecutor.java:205)
at org.eclipse.birt.report.engine.executor.ExtendedGenerateExec utor.execute(ExtendedGenerateExecutor.java:65)
... 59 more
Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot find or process the com.ibm.team.reports.generic.dataSource driver's data source extension configuration.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.ne wException(ExceptionHandler.java:54)
at org.eclipse.birt.data.engine.odaconsumer.Driver.throwConfigE xception(Driver.java:176)
at org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest(Driver.java:165)
at org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSour ceExtensionConfig(Driver.java:123)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExt ensionConfig(Driver.java:78)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getExtension Config(Driver.java:60)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverHel per(Driver.java:93)
at org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDr iverHelper(DriverManager.java:98)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:148)
at org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:190)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:178)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiD ataSource(DataSourceRuntime.java:208)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSour ce(QueryExecutor.java:405)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:315)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:145)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:603)
... 64 more
Caused by: java.lang.IllegalArgumentException: Cannot find the ODA dataSource extension (com.ibm.team.reports.generic.dataSource).
at org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getExtensionManifest(ManifestExplorer.java:200)
at org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest(Driver.java:147)
... 80 more
... 59 more
... 64 more
... 80 more
Re: BirtViewer and the Jazz Data Source [message #552823 is a reply to message #552768] Fri, 13 August 2010 16:13 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Does the Jazz datasource work in the designer? The default runtime does
not contain the Jazz oda driver. If it works in the designer can you
copy the oda runtime driver to the Birt Viewers
/WEB-INF/platform/plugins directory?
Jason
On 8/13/2010 9:12 AM, Krzysiek wrote:
> Hi, I made a report using Birt 2.3.2 and I took data directly from RTC
> the report with Jazz Data Source throw and Exceptions (below)
> Krzysiek
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:174)
> t.java:1293)
> for details:
> ... 59 more
> per(Driver.java:93)
> urce.java:178)
> ... 64 more
> ... 80 more
> ssorImpl.java:48)
> ssorImpl.java:48)
> rovider.java:397)
> CProvider.java:186)
> der.java:323)
> onStrategy.java:32)
> ilter.java:68)
> stValve.java:127)
> rtValve.java:117)
> apter.java:174)
> t.java:1293)
> for details:
> ... 59 more
> per(Driver.java:93)
> urce.java:178)
> ... 64 more
> ... 80 more
Re: BirtViewer and the Jazz Data Source [message #553044 is a reply to message #552823] Mon, 16 August 2010 08:44 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 13 August 2010 12:13
Does the Jazz datasource work in the designer? ,
Yes
Jason
I was not sure which file exactly should I copy to /WEB-INF/platform/plugins so temporary I copied all files from "eclipse dir"/plugins
But now when I tried to preview my report I stuck on "Processing, please wait ..." In designer it takes 4-5 seconds and here I was waiting couple of minutes and no error or result come up.
Re: BirtViewer and the Jazz Data Source [message #553151 is a reply to message #553044] Mon, 16 August 2010 15:00 Go to previous messageGo to next message
You do not want to copy all the files. You may need to start with a
clean 2.6 runtime. I am not sure which plugins implement the Jazz oda,
but I would look for files with oda in the name.
Jason
> Yes
> Quote:
>> The default runtime does not contain the Jazz oda driver. If it works
>> in the designer can you copy the oda runtime driver to the Birt
>> Viewers /WEB-INF/platform/plugins directory?
>> Jason
> dir"/plugins
Re: BirtViewer and the Jazz Data Source [message #553280 is a reply to message #553044] Tue, 17 August 2010 00:28 Go to previous message
Linda ChanFriend
As indicated by the error log:
It is probably a plugin jar file, whose name starts with "com.ibm.team.reports". Also make sure *all* its dependent bundles, including nested ones, are copied as well.
You might want to contact the provider/vendor of the RTC Jazz data source to get the list of related runtime bundles.
A search on the jazz.net/forums seem to show some related topics as well.
Linda
Previous Topic:Add parameters to already existing DataSetHandle (using the birt API)
Next Topic:Run a dataset rather than the report itself
Current Time: Sat Feb 24 20:47:46 GMT 2018
Powered by FUDForum. Page generated in 0.01852 seconds
