Home » Eclipse Projects » BIRT » Customize/Limit available locales in Designer?
Customize/Limit available locales in Designer? [message #550553] Fri, 30 July 2010 14:56 Go to next message
Robert Aust is currently offline Robert Aust
Hi there,
Is there any way to customize/limit the available locales in the BIRT
designer, e.g. in the date/number-formatting properties of data-elements?
I think it would be much easier to use, if I could limit to the 1-2
necessary locales - instead of having to select from this huge list from
"Africaans".... to "White Russian".
Better even, if there would be a way to set a report-wide default-locale
for all [formatting-] elements.
Thanks for any feedback.
Robert
Re: Customize/Limit available locales in Designer? [message #550565 is a reply to message #550553] Fri, 30 July 2010 15:54 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Robert,
For formatting numbers and dates, BIRT uses the default locale. Which
you can also set with viewer parameter (__locale) or in the
Window-Preferences->Report Design->Preview setting page. The Preview
setting is used to test different locales.
Jason
On 7/30/2010 2:57 PM, Robert Aust wrote:
> Hi there,
> Robert
Jason Weathersby
BIRT Exchange
Previous Topic:Birt upgrade openreports Resolved
Next Topic:ReportItemModel extension and defining a JavaObject property
Current Time: Sat May 25 11:42:51 EDT 2013
Powered by FUDForum. Page generated in 0.01482 seconds
