Home » Eclipse Projects » Rich Client Platform (RCP) » JAAS in RCP - Unable to locate a login configuration
JAAS in RCP - Unable to locate a login configuration [message #550401] Fri, 30 July 2010 09:33 Go to next message
Juergen Weber is currently offline Juergen WeberFriend
Member
has somebody managed to get JAAS running in RCP?
It works if I run the product in the IDE, but if I export the product and run the standalone RCP app, I always get
java.io.IOException: Unable to locate a login configuration
But:
new File(System.getProperty("java.security.auth.login.config")).exists() is true !!!
Juergen
Re: JAAS in RCP - Unable to locate a login configuration [message #550665 is a reply to message #550401] Wed, 04 August 2010 06:25 Go to previous message
Member
Well, looks like OSGI and JAAS don't like each other very much.
Seems like one should use the org.eclipse.equinox.security plugin.
I got the example working that is attached to https://bugs.eclipse.org/bugs/show_bug.cgi?id=248067
Cheers, Juergen
Previous Topic:File Browser in ViewPart or Editor?
Next Topic:Selection dialogs initially empty
Current Time: Wed May 23 22:57:35 GMT 2018
Powered by FUDForum. Page generated in 0.01451 seconds
