Home » Eclipse Projects » BIRT » BIRT - Tomcat: Running problem (please help, probably very easy!)(Tomcat, MySQL, Birt 2.6.0: Error when querying sixth or fifth report)
BIRT - Tomcat: Running problem (please help, probably very easy!) [message #550212] Thu, 29 July 2010 14:29 Go to next message
Federico Alvarez is currently offline Federico AlvarezFriend
Hi everyone, I'm a newbie to BIRT and having the most awkward problem.
I designed in RCP my very first report, using BIRT 2.6.0, and accessing a MySQL 5.5.
When run with the tomcat viewer it works perfectly, until I query for the sixth o fifth time!!!
In this last run the webbrowser hangs in the "Processing, wait..." screen.
The logs show nothing weird (to me at last). And no output sent to Catalina.out or tomcat console.
What I was able to see is that in " /opt/tomcat6/webapps/birtviewer/documents/BIRT****/20100726_ 174500_***/ " are the "*.rptdocument" (this folder is the default tmp folder, the * are randomly generated, i have not played with this configuration). For the first 6 runs, there is a folder created and a file in each with a matching size of 155724 bytes. But for the 7th run the size is 62659 bytes.
The content of all files is the same, something like "RPTDOCV2", even in the one with less size.
For this failed run, the "***IMG***" temp folder is not created, for the others yes.
Reloading the "birtviewer" application "solves" the problem for 6 more runs, until another crush happens.
I tried using "run" instead of "frameset", but the result was the same (only difference is that no "*.rptdocument" is created).
Can anyone help me with this issue? Probably it is something silly I'm missing, maybe in design time.
I tried this in two different servers, both running Linux, Tomcat, Java 6, MySQL 5.5.
Thanks in advance.
Federico.
Re: BIRT - Tomcat: Running problem (please help, probably very easy!) [message #550230 is a reply to message #550212] Thu, 29 July 2010 14:48 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Federico,
I have not seen this problem on Tomcat, but can you try changing your
Java Opts in the catalina.bat?
set JAVA_OPTS=%JAVA_OPTS% -Xdebug
-Xrunjdwp:transport=dt_socket,address=8000,server=y,suspend= n
-XX:MaxPermSize=256m
-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogMa nager ..
Add the -XX:MaxPermSize=256m entry.
Jason
> a MySQL 5.5.
> others yes.
> 6, MySQL 5.5.
> Thanks in advance.
> Best regards,
> Federico.
Previous Topic:Setting bar chart to palette value dynamically
Next Topic:Missing TOC for Word
Current Time: Thu May 24 02:38:47 GMT 2018
Powered by FUDForum. Page generated in 0.01365 seconds
