Re: Dynamic Sql query in birt [message #548935 is a reply to message #548764] |
Fri, 23 July 2010 13:41   |
Do all the report parameter detail tables have the same name and number
of columns?
On 7/22/2010 6:20 PM, Smitha wrote:
> I have a scenario where I need to create sql query dynamically based on
> table columns.
> That is, I am passing in a 'report id' as parameter to query.....then
> query fetches all 'report parameters' for that report id and gets
> 'report details' for each of the report parameter. The problem is report
> details table should be picked dynamically based on the 'report level'
> column in the report param table. for example:
> if value for 'report level'= ABC in reportparam table, then details
> table is ABC_report_detals and so on.
> is there any way i can do it with property binder?
> Any help much appreciated!
Re: Dynamic Sql query in birt [message #549003 is a reply to message #548960] |
Fri, 23 July 2010 15:54   |
You should be able to do this with a beforeOpen script on the dataset.
Something like:
this.queryText = "Select * from " +
params["parmtable"].value+"_report_details";
Jason
On 7/23/2010 10:36 AM, Smitha wrote:
> yes, all param details tables have exactly same column names (atleast
> for the columns i need information from)
Re: Dynamic Sql query in birt [message #549029 is a reply to message #549007] |
Fri, 23 July 2010 17:29  |
You could do this with nested tables. Take a look at the attached
example. It does not change the table but that should be doable with
the same scheme.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="outer" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">PRODUCTLINE</property>
<text-property
name="displayName">PRODUCTLINE</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTLINE</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">PRODUCTLINE</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select
CLASSICMODELS.PRODUCTLINES.PRODUCTLINE
from CLASSICMODELS.PRODUCTLINES]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTLINE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>PRODUCTLINE</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTLINE</design:label>
<design:formattingHints>
<design:displaySize>50</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="inner" id="9">
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTNAME</property>
<text-property
name="displayName">PRODUCTNAME</text-property>
</structure>
<structure>
<text-property
</structure>
<structure>
<property name="columnName">PRODUCTSCALE</property>
<text-property
name="displayName">PRODUCTSCALE</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTVENDOR</property>
<text-property
name="displayName">PRODUCTVENDOR</text-property>
</structure>
<structure>
<property
name="columnName">PRODUCTDESCRIPTION</property>
<text-property
name="displayName">PRODUCTDESCRIPTION</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYINSTOCK</property>
<text-property
name="displayName">QUANTITYINSTOCK</text-property>
</structure>
<structure>
<property name="columnName">BUYPRICE</property>
<text-property
name="displayName">BUYPRICE</text-property>
</structure>
<structure>
<property name="columnName">MSRP</property>
<text-property name="displayName">MSRP</text-property>
</structure>
</list-property>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTNAME</property>
</structure>
<structure>
<property name="position">3</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRODUCTSCALE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PRODUCTVENDOR</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">QUANTITYINSTOCK</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">BUYPRICE</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">MSRP</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[var pl =
reportContext.getGlobalVariable("cp");
this.queryText = "Select * from products where productline = '"+pl+"'";
]]></method>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTNAME</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTSCALE</property>
</structure>
<structure>
<property name="nativeName">PRODUCTVENDOR</property>
</structure>
<structure>
<property
name="nativeName">PRODUCTDESCRIPTION</property>
</structure>
<structure>
<property name="nativeName">QUANTITYINSTOCK</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">BUYPRICE</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">MSRP</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from CLASSICMODELS.PRODUCTS
]]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>PRODUCTNAME</design:name>
<design:position>2</design:position>
<design:precision>70</design:precision>
<design:uiHints>
<design:displayName>PRODUCTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTNAME</design:label>
<design:displaySize>70</design:displaySize>
<design:attributes>
<design:position>3</design:position>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>PRODUCTSCALE</design:name>
<design:position>4</design:position>
<design:precision>10</design:precision>
<design:uiHints>
<design:displayName>PRODUCTSCALE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTSCALE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>PRODUCTVENDOR</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PRODUCTVENDOR</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTVENDOR</design:label>
<design:attributes>
<design:name>PRODUCTDESCRIPTION</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>PRODUCTDESCRIPTION</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTDESCRIPTION</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>QUANTITYINSTOCK</design:name>
<design:position>7</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>QUANTITYINSTOCK</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYINSTOCK</design:label>
<design:displaySize>11</design:displaySize>
<design:attributes>
<design:name>BUYPRICE</design:name>
<design:position>8</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>BUYPRICE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>BUYPRICE</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>MSRP</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>MSRP</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>MSRP</design:label>
<design:criteria/>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<label id="82">
<text-property name="text">Look at the expression for
product line in red table. look at the beforeOpen script on the inner
dataset.</text-property>
</label>
<table id="10">
<property name="backgroundColor">#FF8080</property>
<property name="dataSet">outer</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">reportContext.setGlobalVariable( "cp",
dataSetRow["PRODUCTLINE"]);
dataSetRow["PRODUCTLINE"];</expression>
</structure>
</list-property>
<column id="19"/>
<column id="23"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">PRODUCTLINE</text-property>
</label>
</cell>
<cell id="20"/>
</row>
</header>
<detail>
<row id="14">
<cell id="15">
<data id="16">
<property
name="resultSetColumn">PRODUCTLINE</property>
</data>
</cell>
<cell id="21">
<table id="24">
<property
name="backgroundColor">#80FF80</property>
<property name="width">3.90625in</property>
<property name="dataSet">inner</property>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTNAME"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTLINE"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTSCALE"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTVENDOR"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTDESCRIPTION"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["QUANTITYINSTOCK"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["BUYPRICE"]</expression>
<property
</structure>
<structure>
<text-property
type="javascript">dataSetRow["MSRP"]</expression>
<property
</structure>
</list-property>
<column id="74">
<property
name="width">1.1458333333333333in</property>
</column>
<column id="75">
<property
name="width">0.4791666666666667in</property>
</column>
<header>
<row id="25">
<cell id="28">
<label id="29">
<text-property
name="text">PRODUCTNAME</text-property>
</label>
</cell>
<cell id="30">
<label id="31">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="44">
<cell id="47">
<data id="48">
<property
name="resultSetColumn">PRODUCTNAME</property>
</data>
</cell>
<cell id="49">
<data id="50">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="63">
<cell id="65"/>
<cell id="66"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="17">
<cell id="18"/>
<cell id="22"/>
</row>
</footer>
</table>
</body>
</report>
On 7/23/2010 12:27 PM, Smitha wrote:
> yes i could...but whats confusing is that params["parmtable"].value is
> determined by another column in report_params table..
> report_params table has a column named 'report_level' ....so on a
> high-level the query has to be something like:
> A 'report' has many report-params and for each report-param do the
> following:
> if report_level= 'ABC' then select from table 'ABC_details'
> if report_level ='XYZ' then select from table 'XYZ_details' and so on
> so how can i set that condition for a parameter?
FUDForum. Page generated in 0.02141 seconds
