Home » Eclipse Projects » BIRT » Dynamic hyperlink on bar chart series
Dynamic hyperlink on bar chart series [message #548687] Thu, 22 July 2010 16:16 Go to next message
Originally posted by: remkus.wideopenwest.com
I have a report that contains a bar chart. The bar chart series will
have a drill-through to another report.
I'd like to be able to change the report that the interactivity
drills-through based on a report parameter, but I'm a bit confused on
how to access/change the drill-through on a chart series in a script.
Can it be done? Any suggestions?
Re: Dynamic hyperlink on bar chart series [message #548721 is a reply to message #548687] Thu, 22 July 2010 18:03 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Dave,
For chart drill through (Which is stored in the design differently than
a normal drill through) you could do something like:
function beforeDrawSeries( series, isr, icsc )
triglen = series.getTriggers().size();
if( triglen >0 ){
mytarget =
series.getTriggers().get(0).getAction().getValue().getURLVal ues(
).get(0).getBaseUrl();
newtarget = mytarget.replace("reporttarget1.rptdesign",
"reporttarget2.rptdesign");
).get(0).setBaseUrl(newtarget);
Jason
> Thanks
Previous Topic:Using SVG in a PDF report
Next Topic:Actuate 8 Report Errors
Current Time: Sun Feb 25 04:36:10 GMT 2018
Powered by FUDForum. Page generated in 0.02149 seconds
