Home » Eclipse Projects » BIRT » Eclipse Helios & BIRT 2.6 freezes
Eclipse Helios & BIRT 2.6 freezes [message #548072] Tue, 20 July 2010 15:11 Go to next message
Ernst is currently offline ErnstFriend
Hi BIRT Users
Eclipse freezes every time I'm trying to do the following thing:
1. create a new Reporting project
2. create a new Report ==> Eclipse freezes and has to be shot down with the task manager.
I tried this 2 times with a clean all in one 2.6 download. One time on a Win XP machine (32 bit version) an one time on Win 7 (64 bit version) machine. Both show the very same behaviour.
Obviously this makes working with BIRT impossible.
Any ideas about how to come around this problem?
Best Regards
Ernst
Re: Eclipse Helios & BIRT 2.6 freezes [message #548167 is a reply to message #548072] Tue, 20 July 2010 21:46 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Ernst,
What is the full name of the download file you used?
Jason
On 7/20/2010 11:11 AM, Ernst wrote:
> Hi BIRT Users
> the task manager.
> Best Regards
> Ernst
Re: Eclipse Helios & BIRT 2.6 freezes [message #548215 is a reply to message #548167] Wed, 21 July 2010 07:17 Go to previous messageGo to next message
This are the names of the downloaded packages:
32-Bit Win XP system: eclipse-reporting-helios-win32.zip
64-Bit Win 7 system: eclipse-reporting-helios-win32-x86_64.zip
Re: Eclipse Helios & BIRT 2.6 freezes [message #548649 is a reply to message #548215] Thu, 22 July 2010 14:36 Go to previous messageGo to next message
I have tried
and I do not get the freeze.
Can you try this one:
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/R-R1-2_6_0-201006171315/birt-report-designer-al l-in-one-2_6_0.zip
Jason
Re: Eclipse Helios & BIRT 2.6 freezes [message #548951 is a reply to message #548649] Fri, 23 July 2010 14:21 Go to previous messageGo to next message
ivost  is currently offline ivost Friend
I have the same problem - designer freezes during creation of data source. I tried both 32 and 64 bit installs and the link above. Tried with classiccars example and with mysql jdbc source. Tried increasing java memory to 768M in eclipse.ini. Eclipse either freezes or just shuts down. I'm on 64-bit Windows. I'll try on clean VM - any advise is appreciated.
Re: Eclipse Helios & BIRT 2.6 freezes [message #548971 is a reply to message #548951] Fri, 23 July 2010 14:29 Go to previous messageGo to next message
Are you getting any errors in the workspace/.metadata/.log file?
Jason
> appreciated.
Re: Eclipse Helios & BIRT 2.6 freezes [message #548992 is a reply to message #548971] Fri, 23 July 2010 15:44 Go to previous messageGo to next message
I tried on clean 32-bit VM - got same problem with both 2.5.2 and 2.6 - using latest JDK 1.6 - 22
Decided to try with Java 5 - which is hard to get as it's EOL
Lo an behold - 2.6 designer works fine.
I'll stick with 1.5 JDK for now - but there should be some way/setting to make this work with Java 6.
I'll look for any error logs...
Re: Eclipse Helios & BIRT 2.6 freezes [message #549004 is a reply to message #548992] Fri, 23 July 2010 15:59 Go to previous messageGo to next message
Can you also open a bug for this?
Jason
Re: Eclipse Helios & BIRT 2.6 freezes [message #549093 is a reply to message #549004] Sat, 24 July 2010 09:22 Go to previous messageGo to next message
I tried JDK 1.6 19,20 and 21. I tried with Eclipse Helios and Ganymed. I also tried the fixes for Eclipse and JDK 1.6 21 mentioned here http://lt-rider.blogspot.com/2010/07/oracle-jvm-6u21-and-ecl ipse.html (and in a lot of other places).
No luck.
It's not only BIRT that is crashing, also normal JSE developement crashes repeatedly after some minutes. Some times I found java.lang.OutOfMemoryError: PermGen space in the Eclipse log, sometimes nothing was written to the logs.
After all I installed the latest JRockit VM and all of a sudden all problems disapeard.
I did not have any problems running any other Java Applications. All of them work as expecd, except Eclipse.
IMHO there's a genreal problem with Eclipse and the sun/oracle JVM.
Re: Eclipse Helios & BIRT 2.6 freezes [message #549423 is a reply to message #549093] Mon, 26 July 2010 15:07 Go to previous messageGo to next message
Did you open a bug for this?
Jason
On 7/24/2010 5:22 AM, Ernst wrote:
> Hi
> No luck.
> problems disapeard.
Re: Eclipse Helios & BIRT 2.6 freezes [message #552852 is a reply to message #549423] Fri, 13 August 2010 19:13 Go to previous message
Arche TyFriend
I have the same problem before but it is working now after I reinstall the java using build 1.6.0_21-b07 not the b06.
Previous Topic:Multiple Charts on a Canvas
Next Topic:Table breaking with very large data
Current Time: Sun Apr 22 16:31:38 GMT 2018
Powered by FUDForum. Page generated in 0.03178 seconds
