Home » Eclipse Projects » BIRT » Upgrade BIRT 2.3.2 to BIRT2.6
Upgrade BIRT 2.3.2 to BIRT2.6 [message #547757] Mon, 19 July 2010 14:45 Go to next message
shammad  is currently offline shammad Friend
Hi all,
I have a problem when I tried to update my java application to using BIRT2.6 (NOT WEB)
I replaced the following directory for BIRT :
1- lib
2- plugins
3- configuration
but when I tried to create the engine I faced the following exception:
java.lang.NoSuchMethodError: org.eclipse.birt.report.engine.api.EngineConfig.getLogRollin gSize()
and this is the code which I used to create the engine :
EngineConfig config = new EngineConfig();
config.setEngineHome(home);//the location of the engine plug-ins and jar files
config.setLogConfig(home+"/BIRT_log", Level.ALL); //use null if you do not want a log file
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
engine = factory.createReportEngine( config ); //here the error happened
please advice,
thanks in advance
Saed
Re: Upgrade BIRT 2.3.2 to BIRT2.6 [message #547785 is a reply to message #547757] Mon, 19 July 2010 15:40 Go to previous messageGo to next message
Katerina  is currently offline Katerina Friend
Hi Saed,
had you included any of the BIRT 2.3.2 .jar files in your application before? You will have to update those too.
Katerina
Re: Upgrade BIRT 2.3.2 to BIRT2.6 [message #547923 is a reply to message #547757] Tue, 20 July 2010 08:11 Go to previous message
Yes I replace all BIRT2.3.2 jars with BIRT 2.6 jars,
please advice
thanks,
Saed
Previous Topic:http 401 error (xml data source) with viewer deployed in tomcat
Next Topic:Filtering a aggregation: CONCATENATE
Current Time: Thu Jun 21 07:02:02 GMT 2018
Powered by FUDForum. Page generated in 0.01498 seconds
