Home » Eclipse Projects » BIRT » NullPointerException in ReportDesigner (Debug Report)(BIRT 2.6 on Eclipse 3.6 (Helios) - Get NullPointerException in ReportDesigner)
NullPointerException in ReportDesigner (Debug Report) [message #547500] Sat, 17 July 2010 20:13 Go to next message
ISK  is currently offline ISK Friend
Hi All,
While playing with BIRT I created an empty report filled it with data from sample db and tried to debug it:
Navigator -> (right click on rptdesign file) -> Report -> Debug Report
As a result I've got the NullPointerException
Follow this link to see the stack trace:
http://pastebin.com/embed_js.php?i=qwsCAWE5
I'm working with a plugin version of report designer.
BRIT 2.6
Eclipse 3.6 Helios
Thanks in advance for your help
Ilya
icon5.gif  Re: NullPointerException in ReportDesigner (Debug Report) [message #547888 is a reply to message #547500] Tue, 20 July 2010 06:06 Go to previous messageGo to next message
Hi All
I'm currently evaluating BIRT for our project and this is a no go issue for me right now - could somebody help?
Ilya
Re: NullPointerException in ReportDesigner (Debug Report) [message #548120 is a reply to message #547888] Tue, 20 July 2010 17:04 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Ilya,
Can you post the report? Are you setting any breakpoints in script?
Does the report run without debugging it?
Jason
On 7/20/2010 2:06 AM, ISK wrote:
> Hi All
> Ilya
Re: NullPointerException in ReportDesigner (Debug Report) [message #548133 is a reply to message #547500] Tue, 20 July 2010 18:13 Go to previous messageGo to next message
Hi Jason,
Thank you for your help.
1. Report runs fine when I use preview tab in designer or when I run it
from dynamic menu using "Report/Run Report"
2. I do not set any beakpoints
3. My report xml file is here:
http://pastebin.com/VfyLCUDv
Ilya
Re: NullPointerException in ReportDesigner (Debug Report) [message #548166 is a reply to message #548133] Tue, 20 July 2010 21:35 Go to previous messageGo to next message
Debugging the report is usually used when you want to debug Java or
JavaScript event handlers. Look at the report item in the debug
perspective. This does appear to be a bug in the debugger. Can you
select the view report in web viewer from the toolbar and see if that works.
Jason
On 7/20/2010 2:13 PM, ISK wrote:
> Hi Jason,
> Ilya
Re: NullPointerException in ReportDesigner (Debug Report) [message #548196 is a reply to message #547500] Wed, 21 July 2010 04:47 Go to previous messageGo to next message
"View Report" from the toolbar works, it also creates word and HTML reports without any problems.
Debugging does not work from any of the available places (Dynamic menu on the right-click, Run menu) and fails with the same NullPointerException.
Re: NullPointerException in ReportDesigner (Debug Report) [message #548647 is a reply to message #548196] Thu, 22 July 2010 14:32 Go to previous messageGo to next message
I tried this as well and it does appear to be a bug. I will log it.
You can still debug the run task, but the error comes on the render task.
Jason
Re: NullPointerException in ReportDesigner (Debug Report) [message #548648 is a reply to message #548647] Thu, 22 July 2010 14:34 Go to previous message
Here is the bug entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=320639
On 7/22/2010 10:32 AM, Jason Weathersby wrote:
> I tried this as well and it does appear to be a bug. I will log it. You
> Jason
Previous Topic: Change chart series color via script in birt 2.3.1
Next Topic:The viewing session is not available or has expired.
Current Time: Sat Apr 21 00:19:30 GMT 2018
Powered by FUDForum. Page generated in 0.02448 seconds
