Home » Eclipse Projects » BIRT » Dynamic report title
Dynamic report title [message #547339] Fri, 16 July 2010 10:31 Go to next message
Originally posted by: pschoenb.gmx.de
we want to generate a report from EPF models. On top of the report,
there should be the name of the model. I tried to define a separate data
source and data set just containing one row with the title. Then, I
tried to include the dataset row via a dynamic text field. However,
nothing is displayed.
Is this the right approach? What am I missing?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Dynamic report title [message #547365 is a reply to message #547339] Fri, 16 July 2010 13:24 Go to previous message
Paul Kofon is currently offline Paul KofonFriend
You need to bind the dynamic text element to the data set you've created, if you haven't done so. Then specify a value for it via "Available Column Bindings" in Expression Builder. I hope that helps.
Previous Topic:Properties of data source from library overridden
Next Topic:Data cube: add another column for aggregation
Current Time: Fri Jan 19 07:57:43 GMT 2018
Powered by FUDForum. Page generated in 0.02069 seconds
