Home » Eclipse Projects » BIRT » DataSource Property Binding (what object can I access in this expression builder ?)
DataSource Property Binding [message #547295] Fri, 16 July 2010 04:54 Go to next message
Cyril Rognon is currently offline Cyril Rognon
Hello all,
Birt rocks and I have been using it for a while now. These days I have been using much of xml datasources.
This has taken me to the path of dynamic xml datasources.
Now I have succeeded in handling dynamic datasources with PropertyBinding : I can set the url of the xml datasource in this simple property binding field.
The trouble is I would like to have access to the default value of the FileList property of the Datasource.
I have tried to use this.getExtensionProperty in this expression builder but it says this method doesn't exists in Object class.
Is this a bug or can I really get to the datasource itself or any object that could get me the filelist property ? Or a way to test if the property binding must not occur ?
Thanks for your help, I hope I have been clear enough.
Cyril
[Updated on: Fri, 16 July 2010 04:54]
Report message to a moderator
Re: DataSource Property Binding [message #547377 is a reply to message #547295] Fri, 16 July 2010 09:53 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Cyril,
I normally just use the beforeOpen script, but even in the expression
builder on the property binding you could enter something like:
currxmlds =reportContext.getDesignHandle().findDataSource("Data
Source").getProperty("FILELIST")
There should be a local property for this. If you want to add an
enhancement that would be good.
Jason
On 7/16/2010 4:54 AM, Cyril Rognon wrote:
> Hello all,
> Cyril
Jason Weathersby
BIRT Exchange
Previous Topic:BirtDuration.day
Next Topic:Upgrade Birt Engine 2.3.2 to 2.6
Current Time: Sat May 18 04:40:42 EDT 2013
Powered by FUDForum. Page generated in 0.01807 seconds
