Home » Eclipse Projects » BIRT » Layout problem
Layout problem [message #547128] Thu, 15 July 2010 15:54 Go to next message
Originally posted by: pschoenb.gmx.de
my report layout is as follows and I want to render the report to PDF:
header
| name 1 | data 1 |
| name 2 | data 2 |
The "data" column consists of lots of HTML text. However, as soon as I
insert the data column, all fonts become unreadable small and the table
width then is only about a teneth of the paper width.
What could be wrong?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Layout problem [message #547130 is a reply to message #547128] Thu, 15 July 2010 16:06 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
I suspect either CSS or other style interactions.
Remove all styling and make sure you have no CSS references, then run the report in HTML and also in PDF. See if the issue still arises and whether it appears in all types of report elements or only in specific ones. Also, what are the master page specifications in your report?
Re: Layout problem [message #547151 is a reply to message #547130] Thu, 15 July 2010 17:11 Go to previous messageGo to next message
> report?
I have no styling except that I have specified fonts and font sizes. As
soon as I remove the HTML content, fonts become larger but still too
small. However, the width of the page content is still much too small.
Patrick
Re: Layout problem [message #547157 is a reply to message #547128] Thu, 15 July 2010 17:37 Go to previous messageGo to next message
And the master page specifications? Also, is your report (on the layout canvas under properties) set to auto layout or fixed layout?
Re: Layout problem [message #547159 is a reply to message #547128] Thu, 15 July 2010 17:38 Go to previous message
Actually, best for this is for you to create a similar report against the sample Derby database that ships with BIRT and post that report here. that way we all can run it and see the issue.
Previous Topic:Federal BIRT Competition
Next Topic:Properties of data source from library overridden
Current Time: Mon Apr 23 21:35:53 GMT 2018
Powered by FUDForum. Page generated in 0.01491 seconds
