Home » Eclipse Projects » BIRT » Properties of data source from library overridden
Properties of data source from library overridden [message #547106] Thu, 15 July 2010 14:42 Go to next message
Originally posted by: remkus.wideopenwest.com
Here's something that's always annoyed me ... maybe someone can weigh in
with a solution ..
I'll use a data source from a library in a report.
Then, instead of opening the library and changing the data URL, ID or
password there, inadvertently open the data source from my report.
Now, I've overridden the properties of the data source in my report ...
if I change them in the library, it doesn't matter.
That behavior itself isn't that bad ... what bothers me is that the
designer shows me the chain-link icon that tells me I added the object
from a library, but unless I think to look at the XML, I have no clue
that the object is now using overridden properties.
I think it'd be nice to have the report designer give you an indication
that an object had a library item's properties extended without having
to check the XML. It'd be even nicer to have an easy mechanism for
undoing those overrides.
Any thoughts? Am I the only one that's bothered by this?
Re: Properties of data source from library overridden [message #547114 is a reply to message #547106] Thu, 15 July 2010 15:23 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Dave,
Take a look at the new and notable for 2.6:
http://www.eclipse.org/birt/phoenix/project/notable2.6.php#j ump_11
Jason
> with a solution ..
> Thanks
Re: Properties of data source from library overridden [message #547138 is a reply to message #547106] Thu, 15 July 2010 16:24 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
I think the only way to restore the link (other than dropping and readding the reference) is to go into the XML and clean up that clause.
Re: Properties of data source from library overridden [message #547319 is a reply to message #547114] Fri, 16 July 2010 10:11 Go to previous message
Jason,
This looks good! ... for now, my use is tethered to 2.2.2, but I'm glad
to hear this has been addressed!
On 07/15/2010 11:23 AM, Jason Weathersby wrote:
> Dave,
> Jason
>> with a solution ..
>> Thanks
Previous Topic:Layout problem
Next Topic:Dynamic report title
Current Time: Sun Feb 18 11:04:59 GMT 2018
Powered by FUDForum. Page generated in 0.01690 seconds
