Home » Eclipse Projects » BIRT » Grouping problem
Grouping problem [message #546869] Wed, 14 July 2010 12:45 Go to next message
Originally posted by: pschoenb.gmx.de
I have three data set fields (all of type string): header, name, and
data.
My header is a string that starts with a section number, though, like:
1.2.13. Sample header
Several adjacent rows, consisting of different name/data pairs can share
the same header. If this is the case, I want the header to be displayed
once only. That means, I want a layout like:
header
| name 1 | data 1 |
| name 2 | data 2 |
I tried using a group for the header, but then, the header gets sorted,
which shuffles my sections, since it sorts lexically and not
numerically.
How can I achieve this layout without the header getting sorted?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Grouping problem [message #546878 is a reply to message #546869] Wed, 14 July 2010 13:35 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
I would create an additional field in my dataset representing the header in a format that can be sorted - something like 00001-00002-00013 for the item you show. Since your header is a string, you should be able to do that either in the underlying SQL with its string manipulation functions or at the BIRT dataset layer with the javascript string manips.
Re: Grouping problem [message #546959 is a reply to message #546878] Wed, 14 July 2010 17:33 Go to previous messageGo to next message
I tried that. However, if I create a group on header and add the new
sort key in the sorting tab of the group, it still sorts lexically on
the header.
Why?
Patrick
Re: Grouping problem [message #546969 is a reply to message #546869] Wed, 14 July 2010 18:46 Go to previous messageGo to next message
It sorts lexically because the item is a string. You could, I suppose, create three auxiliary integer fields and do a combination key sort, but I showed the section number as zero-padded to guarantee that the lexical sort would match the hierarchical numeric sort. The zero-padding is required to make that work.
Re: Grouping problem [message #547084 is a reply to message #546969] Thu, 15 July 2010 11:16 Go to previous message
> the header.
> Why?
That means, I created the zero-padded key and added it to the "Sorting
tab" of my group, but I do not see any change yet.
Patrick
Previous Topic:JDBC Mysql connection
Next Topic:Federal BIRT Competition
Current Time: Fri Apr 20 07:10:57 GMT 2018
Powered by FUDForum. Page generated in 0.01796 seconds
