Home » Eclipse Projects » BIRT » HOW TO CREATE A BIRT REPORT LIBRARY(BIRT Report Libraries)
HOW TO CREATE A BIRT REPORT LIBRARY [message #546517] Tue, 13 July 2010 09:11
Paul Bappoo is currently offline Paul BappooFriend
A BIRT report library is a collection of visual and textual report elements that can be re-used in multiple projects. The primary purpose of library creation and management in the BIRT environment is to share data reports across different users. The administrator or developer can create and publish a library at a shared location and populate it with the relevant data. For sharing, usage rights can be defined in the library properties. A BIRT report library is used to share information such as corporate header, customized styles, images and datasets.
Steps to Create a BIRT Report Library
Create a new library from either the 'NEW' option or from 'Navigator' bar. A BIRT library file has an extension .rptlibrary.
Add report elements to the library. You can add datasets, themes, images, master pages, items and styles to the library.
For datasets, the developer has to define the data source. Also, define column mapping properties, which include name of the element, path and the string type. Report parameters can be attached to the datasets stored in the library. When these datasets are used in a report, they can access parameters from the library.
For uploading themes to the library, corresponding .CSS files have to be attached. A theme is basically a collection of styles that is used in report generation.
Define the properties of the report library elements.
Publish the library into the resource folder to allow sharing across different users.
Review the library in Library Explorer.
Multiple libraries can be created within a library.
By following the abovementioned procedure, a developer can build different libraries for effective data management and sharing. A BIRT library can be updated and revised by the developer or administrator. The themes and datasets stored in the library can be exported to develop different reports.
The full version of this report, including screen shots in full colour pdf is available for free download at http://www.BIRTReporting.com
Previous Topic: HOW TO CREATE A BIRT REPORT LIBRARY
Next Topic:How to create an index with page numbering
Current Time: Tue Feb 20 19:53:46 GMT 2018
Powered by FUDForum. Page generated in 0.01320 seconds
