Home » Eclipse Projects » BIRT » Problem with Tables
Problem with Tables [message #546436] Mon, 12 July 2010 18:30 Go to next message
Originally posted by: pschoenb.gmx.de
I am quite new to BIRT, and I am building a report using scripting.
Although I was able to build a simple example successfully, I have
problems in my main app to get anything displayed in a table.
To find out what is happening, I installed a row event handler. I
noticed that onPrepare() gets called, but onCreate() and onRender()
never is called.
I checked my dataset and it seems that the data is filled in correctly.
What could be wrong?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Problem with Tables [message #546455 is a reply to message #546436] Mon, 12 July 2010 20:06 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Are you sure the table is bound to the dataset? Look at the binding tab
in the properties editor.
Jason
On 7/12/2010 2:30 PM, Patrick Schönbach wrote:
> never is called.
Re: Problem with Tables [message #546550 is a reply to message #546455] Tue, 13 July 2010 10:38 Go to previous messageGo to next message
Yes, the table *is* bound to the dataset.
Patrick
Re: Problem with Tables [message #546568 is a reply to message #546550] Tue, 13 July 2010 11:25 Go to previous messageGo to next message
For the table, onPrepare(), onCreate() and onRender() is called
correctly. However, for the detail row, only onPrepare() is called. Due
to some unfortunate dependency, I am stuck with Eclipse 3.3 and BIRT
2.2.2.
Patrick
Re: Problem with Tables [message #546606 is a reply to message #546568] Tue, 13 July 2010 14:18 Go to previous messageGo to next message
Can you post the report?
> 2.2.2.
Re: Problem with Tables [message #546727 is a reply to message #546606] Tue, 13 July 2010 23:47 Go to previous message
Patrick,
I looked at your report. Where do you have the dataset eventhandler
class located?
Are you sure it is being called? The row event adapter will not be
called if no rows are available in the dataset.
Jason
>> 2.2.2.
Previous Topic:Error in chart
Next Topic:Viewer web.xml being ignored in 2.5.2?
Current Time: Fri Apr 20 10:45:16 GMT 2018
Powered by FUDForum. Page generated in 0.01620 seconds
