Home » Eclipse Projects » BIRT » Highlights for one Row in bevorFactory script
Highlights for one Row in bevorFactory script [message #546294] Mon, 12 July 2010 12:11 Go to next message
pigargo is currently offline pigargoFriend
I am using the following script to generate variable highlightrules:
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments.structures);
var th = reportContext.getDesignHandle().findElement("mytable");
var ch = th.getColumns().get(0);
var hr = StructureFactory.createHighlightRule();
for(jj=6; jj<= 20; jj++ ){
hr.setOperator(DesignChoiceConstants.MAP_OPERATOR_EQ);
hr.setTestExpression("row[\"MYSIZE\"]");
hr.setValue1(jj);
hr.setProperty(HighlightRule.FONT_SIZE_MEMBER, jj+"pt");
var ph = ch.getPropertyHandle(StyleHandle.HIGHLIGHT_RULES_PROP);
ph.addItem(hr);
If I set the findElement to mytable all will be fine. But in mytable there are 2 rows an I only want to set the highlights for on row. How can I set the findElement to get only my row1? I tried it in many ways but they all end with an error, because my row has no name (it's not possible to set a name for a row) and to send the Element-ID for the findElement function gives also an error.
pigargo
Re: Highlights for one Row in bevorFactory script [message #546364 is a reply to message #546294] Mon, 12 July 2010 14:26 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
To get a detail row with the table handle you should be able to use:
tabledetail = th.getDetail( ).get( 0 );
If you have more than one detail just increment the get:
tabledetail = th.getDetail( ).get( 1 );
If you set an elementid you can also always use:
reportContext.getDesignHandle().getElementByID(idofitem)
Jason
On 7/12/2010 8:11 AM, pigargo wrote:
> Hello,
> ments.structures);
> hr.setValue1(jj);
> ph.addItem(hr);
> pigargo
Re: Highlights for one Row in bevorFactory script [message #546501 is a reply to message #546364] Tue, 13 July 2010 08:15 Go to previous message
Hallo Jason,
this was a greate help to design my report.
Thank you very much.
pigargo
Previous Topic:JDBC Mysql connection
Next Topic: HOW TO CREATE A BIRT REPORT LIBRARY
Current Time: Wed Jan 24 10:05:54 GMT 2018
Powered by FUDForum. Page generated in 0.01493 seconds
