Home » Eclipse Projects » BIRT » JDBC Mysql connection
icon4.gif  JDBC Mysql connection [message #546242] Mon, 12 July 2010 05:29 Go to next message
Max is currently offline Max
Hello.
I need to connect to the database and i use mysql-connector-java-5.1.8 driver to do it as well. I made JDBC connection, than entered valid information in all text fields. I tested the connection and its was successful. But when i created new data set, there were not all the tables from a my DB, there was only a half of all. Why is it so? And how can i solve this problem?
Thank you.
Re: JDBC Mysql connection [message #546363 is a reply to message #546242] Mon, 12 July 2010 10:16 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Max,
Take a look at windows->preferences->Report Design->Data Set
Editor->JDBC Data Set. Are you displaying more schemas or tables
defined in this preference?
Jason
On 7/12/2010 5:29 AM, Max wrote:
> Hello.
> Thank you.
Jason Weathersby
BIRT Exchange
Re: JDBC Mysql connection [message #546484 is a reply to message #546242] Tue, 13 July 2010 02:24 Go to previous message
Jason
Thank you very mach Smile I didn`t know it. All works brilliant. Thanks for the help.
Best Regards, Max.
Previous Topic:developer
Next Topic:Highlights for one Row in bevorFactory script
Current Time: Wed May 22 05:16:10 EDT 2013
Powered by FUDForum. Page generated in 0.01603 seconds
