Home » Eclipse Projects » Equinox » New dependency of p2 SDK?(unwanted menu contributions after upgrade to 3.6)
New dependency of p2 SDK? [message #544026] Thu, 01 July 2010 07:55 Go to next message
Thomas Blattner is currently offline Thomas Blattner
Hello all,
I use p2 update mechanism in my feature based eclipse product. It seems that after migration to HELIOS Release there is a new dependency to org.eclipse.workbench.texteditor. At least when removing this plugin the "Install New Software" and "Check for Updates" contributions disappear.
When adding this plugin to my App I get some new and unwanted menu contributions, like 'Last Edit Location".
Is there a way to prevent this? Does anyone know about this problem?
Any help is highly appreciated.
Best regards
Thomas
Re: New dependency of p2 SDK? [message #544480 is a reply to message #544026] Fri, 02 July 2010 15:26 Go to previous messageGo to next message
Eric Jain is currently offline Eric Jain
I've noticed this, too. Looks like org.eclipse.equinox.p2.ui.sdk depends on org.eclipse.compare which in turn depends on several bundles including org.eclipse.ui.workbench.texteditor. Not only does this end up adding a dozen or so MB to our RCP app, but it also causes all kinds of unwanted contributions to appear. Hope there is a workaround for this!
Re: New dependency of p2 SDK? [message #547029 is a reply to message #544480] Thu, 15 July 2010 01:53 Go to previous messageGo to next message
Stephen Egan is currently offline Stephen Egan
Also have the same problem. Console log below:
!SESSION 2010-07-15 15:46:49.563 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_AU
Framework arguments: -product au.csiro.cse.usp.auszeh.dst2.product
Command-line arguments: -product au.csiro.cse.usp.auszeh.dst2.product -data C:\Users\ega024\Projects\AusZEH\DST2\Workspace/../runtime-Au sZEH-DST2.product -dev file:C:/Users/ega024/Projects/AusZEH/DST2/Workspace/.metadat a/.plugins/org.eclipse.pde.core/AusZEH-DST2.product/dev.prop erties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2010-07-15 15:46:50.794
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-15 15:46:50.794
!MESSAGE Bundle reference:file:/C:/Users/ega024/Projects/AusZEH/DST2/Workspa ce/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plug ins/org.eclipse.equinox.p2.ui.sdk_1.0.100.v20100513.jar was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk 2 0 2010-07-15 15:46:50.795
!MESSAGE Missing required bundle org.eclipse.compare_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2010-07-15 15:46:50.798
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-07-15 15:46:50.799
!MESSAGE Bundle org.eclipse.equinox.p2.ui.sdk_1.0.100.v20100513 [213] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.p2.ui.sdk 2 0 2010-07-15 15:46:50.799
Re: New dependency of p2 SDK? [message #550704 is a reply to message #544026] Wed, 04 August 2010 03:54 Go to previous messageGo to next message
Philipp Nanz is currently offline Philipp Nanz
Member
Same here, this is really annoying... A work-around has been proposed here that involves copying and modifying the org.eclipse.equinox.p2.ui.sdk plugin.
[Updated on: Wed, 04 August 2010 03:54]
Report message to a moderator
Re: New dependency of p2 SDK? [message #552486 is a reply to message #550704] Thu, 12 August 2010 07:26 Go to previous message
Michael Spector is currently offline Michael Spector
I've reported a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=322505
Please vote.
Previous Topic:Export-Package constraints problem
Next Topic:java.lang.IllegalAccessError: class cannot access its superclass
Current Time: Thu May 23 20:20:57 EDT 2013
Powered by FUDForum. Page generated in 0.01728 seconds
