Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP & BIRT
TPTP & BIRT [message #54593] Fri, 24 February 2006 00:35
Andrzej Roszkowski is currently offline Andrzej RoszkowskiFriend
--------------090706060404050503060001
Content-Type: text/plain; charset=ISO-8859-2; format=flowed
Hello!
Cannot run BIRT report on all existings artifacts (Test,Profile etc).
After generating a report popup notifies that :
IWAT4022E An error happened during report generation
Error: The design file <stram> has error and cannot be run
in log:
org.eclipse.birt.report.engine.api.EngineException: The design file
<stream> has error and can not be run.
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:167)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:137)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:238)
org.eclipse.tptp.platform.report.birt.ui.internal.BIRTReport Generator.generateHTMLReport(BIRTReportGenerator.java:48)
org.eclipse.tptp.platform.report.birt.ui.internal.BIRTReport sWizard.generate(BIRTReportsWizard.java:192)
org.eclipse.hyades.test.ui.internal.wizard.ReportWizard$Fini shOperation.execute(ReportWizard.java:182)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:98)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1721)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:110)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.hyades.test.ui.internal.wizard.ReportWizard.perf ormFinish(ReportWizard.java:139)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:680)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1021)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2867)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2572)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.hyades.test.ui.internal.navigator.action.OpenRep ortAction.run(OpenReportAction.java:49)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: Error.DesignFileException.SYNTAX_ERROR - 1 errors found!
1.) org.eclipse.birt.report.model.parser.DesignParserException (code =
Error.DesignParserException.FILE_NOT_FOUND, message : The file
"<stream>" is not found.)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:166)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:135)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:177)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:133)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:93)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:161)
.... 47 more
in platform.txt output from eclipse configuration detaails
notice that extensions are located outside default plugin/fature tree.
second - in design file data source is set to XML file d:\birt.xml -
maybe here is problem - no drive D (hehe :D ) at all ;)
never tried this under MS but have no place to do it ...
name="platform.txt"
Content-Disposition: inline;
filename="platform.txt"
*** Date: Fri Feb 24 01:30:25 GMT+01:00 2006
*** Platform Details:
*** System properties:
eclipse.application=3Dorg.eclipse.ui.ide.workbench
eclipse.buildId=3DM20050929-0840
eclipse.commands=3D-os
linux
-ws
gtk
-arch
x86
-launcher
/home/thomas/eclipse-3.1/./eclipse
-name
Eclipse
-showsplash
600
-exitdata
39000a
-vm
/usr/lib/java/bin/java
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1140740327971
eclipse.vm=3D/usr/lib/java/bin/java
eclipse.vmargs=3D-Xms128m
-Xmx512m
-jar
/home/thomas/eclipse-3.1/./startup.jar
eof=3Deof
file.encoding=3DANSI_X3.4-1968
file.encoding.pkg=3Dsun.io
file.separator=3D/
java.awt.graphicsenv=3Dsun.awt.X11GraphicsEnvironment
java.awt.printerjob=3Dsun.print.PSPrinterJob
java.class.path=3D/home/thomas/eclipse-3.1/./startup.jar
java.class.version=3D49.0
java.endorsed.dirs=3D/usr/lib/jdk1.5.0_04/jre/lib/endorsed
java.ext.dirs=3D/usr/lib/jdk1.5.0_04/jre/lib/ext
java.home=3D/usr/lib/jdk1.5.0_04/jre
java.io.tmpdir=3D/tmp
java.library.path=3D/usr/lib/jdk1.5.0_04/jre/lib/i386/client :/usr/lib/jdk=
1.5.0_04/jre/lib/i386:/usr/lib/jdk1.5.0_04/jre/../lib/i386:: /usr/lib/mozi=
lla-1.7.12:/usr/lib/mozilla-1.7.12
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.5.0_04-b05
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.5
java.vendor=3DSun Microsystems Inc.
java.vendor.url=3Dhttp://java.sun.com/
java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
java.version=3D1.5.0_04
java.vm.info=3Dmixed mode, sharing
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DSun Microsystems Inc.
java.vm.version=3D1.5.0_04-b05
line.separator=3D
org.osgi.framework.bootdelegation=3D*
org.osgi.framework.executionenvironment=3DJ2SE-1.5
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DLinux
org.osgi.framework.os.version=3D2.6.9THOMAS
org.osgi.framework.processor=3Di386
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activity,j=
avax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax. imageio,javax=
=2Eimageio.event,javax.imageio.metadata,javax.imageio.plugin s.bmp,javax.i=
mageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,j avax.manageme=
nt,javax.management.loading,javax.management.modelmbean,java x.management.=
monitor,javax.management.openmbean,javax.management.relation ,javax.manage=
ment.remote,javax.management.remote.rmi,javax.management.tim er,javax.nami=
ng,javax.naming.directory,javax.naming.event,javax.naming.ld ap,javax.nami=
ng.spi,javax.net,javax.net.ssl,javax.print,javax.print.attri bute,javax.pr=
int.attribute.standard,javax.print.event,javax.rmi,javax.rmi .CORBA,javax.=
rmi.ssl,javax.security.auth,javax.security.auth.callback,jav ax.security.a=
uth.kerberos,javax.security.auth.login,javax.security.auth.s pi,javax.secu=
rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.transact ion,javax.tra=
nsaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace ,javax.xml.pa=
rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax=
,javax.xml.transform.stream,javax.xml.validation,javax.xml.x path,org.ietf=
=2Ejgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.po rtable,org.om=
g.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA .portable,org=
=2Eomg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingCo=
ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic,or=
g.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org .omg.DynamicA=
ny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage ,org.omg.IOP.=
CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,o rg.omg.Portab=
leInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableS=
erver.CurrentPackage,org.omg.PortableServer.POAManagerPackag e,org.omg.Por=
tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableSe=
rver.ServantLocatorPackage,org.omg.SendingContext,org.omg.st ub.java.rmi,o=
rg.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c. dom.ls,org.xm=
l.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.3.0
org.osgi.supports.framework.extension=3Dtrue
os.arch=3Di386
os.name=3DLinux
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.core.runtime@2:start, org.eclipse.update.confi=
gurator@3:start
osgi.bundlestore=3D/home/thomas/eclipse-3.1/configuration/or g.eclipse.osg=
i/bundles
osgi.configuration.area=3Dfile:/home/thomas/eclipse-3.1/conf iguration/
osgi.framework=3Dfile:/home/thomas/eclipse-3.1/plugins/org.e clipse.osgi_3=
=2E1.2.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.1.2
osgi.install.area=3Dfile:/home/thomas/eclipse-3.1/
osgi.instance.area=3Dfile:/home/thomas/workspace3.1/
osgi.instance.area.default=3Dfile:/home/thomas/workspace/
osgi.logfile=3D/home/thomas/workspace3.1/.metadata/.log
osgi.manifest.cache=3D/home/thomas/eclipse-3.1/configuration /org.eclipse.=
osgi/manifests
osgi.nl=3Den_US
osgi.os=3Dlinux
osgi.splashLocation=3D/home/thomas/eclipse-3.1/plugins/org.e clipse.platfo=
rm_3.1.2/splash.bmp
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3D/home/thomas/eclipse-3.1/plugins
osgi.ws=3Dgtk
path.separator=3D:
sun.arch.data.model=3D32
sun.boot.class.path=3D/usr/lib/jdk1.5.0_04/jre/lib/rt.jar:/u sr/lib/jdk1.5=
=2E0_04/jre/lib/i18n.jar:/usr/lib/jdk1.5.0_04/jre/lib/sunrsa sign.jar:/usr=
/lib/jdk1.5.0_04/jre/lib/jsse.jar:/usr/lib/jdk1.5.0_04/jre/l ib/jce.jar:/u=
sr/lib/jdk1.5.0_04/jre/lib/charsets.jar:/usr/lib/jdk1.5.0_04 /jre/classes
sun.boot.library.path=3D/usr/lib/jdk1.5.0_04/jre/lib/i386
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3D
sun.io.unicode.encoding=3DUnicodeLittle
sun.jnu.encoding=3DANSI_X3.4-1968
sun.management.compiler=3DHotSpot Client Compiler
sun.os.patch.level=3Dunknown
tptp.automation.command=3Dexecute
user.country=3DUS
user.dir=3D/home/thomas/eclipse-3.1
user.home=3D/home/thomas
user.language=3Den
user.name=3Dthomas
user.timezone=3DGMT+01:00
workspace.projectclasspath=3D/home/thomas/workspace3.1/tttt/ bin
*** Features:
de.strutsbox (2.0.0) "StrutsBox Plug-in"
org.eclipse.birt (2.0.0) "Business Intelligence and Reporting Tools"
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.2) "Eclipse Modeling Framework (EMF) Programmers=
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO) Pro=
grammers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO) =
Source"
org.eclipse.emf.source (2.1.2) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.jdt (3.1.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jsf (0.1.0) "JavaServer Faces Tools"
org.eclipse.jst (1.0.0) "J2EE Standard Tools"
org.eclipse.pde (3.1.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.2) "Eclipse Plug-in Development Environment D=
eveloper Resources"
org.eclipse.platform (3.1.2) "Eclipse Platform"
org.eclipse.platform.source (3.1.2) "Eclipse Platform Plug-in Developer R=
esources"
org.eclipse.rcp (3.1.2) "Eclipse RCP"
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.2) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.1.1) "Eclipse SDK Examples"
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support"
org.eclipse.tptp.monitoring (4.1.0.1) "TPTP Monitoring"
org.eclipse.tptp.monitoring.profile.server (4.1.0.1) "TPTP Profile On Ser=
ver Logging Utility"
org.eclipse.tptp.monitoring.report.birt (4.1.0.1) "BIRT Monitor Reports f=
or TPTP Branding Plugin"
org.eclipse.tptp.platform.analysis (4.1.0) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.engine (4.1.0) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core (4.1.0.1) "TPTP Platform"
org.eclipse.tptp.platform.lta (4.1.0) "TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit (4.1.0) "TPTP ProbeKit"
org.eclipse.tptp.platform.profile.server (4.1.0.1) "TPTP Profile on Serve=
r"
org.eclipse.tptp.platform.report (4.1.0.1) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt (4.1.0.1) "BIRT Reporting for TPTP =
Branding plugin"
org.eclipse.tptp.platform.samples (4.1.0) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.ui (4.1.0) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace (4.1.0.1) "TPTP Platform Trace"
org.eclipse.tptp.test (4.1.0.1) "TPTP Test"
org.eclipse.tptp.test.auto (4.1.0) "TPTP Automated GUI Recording and Play=
back"
org.eclipse.tptp.test.report.birt (4.1.0.1) "BIRT Test Reports for TPTP B=
randing Plugin"
org.eclipse.tptp.test.samples (4.1.0) "TPTP Test Samples"
org.eclipse.tptp.test.tools (4.1.0) "TPTP Test Tools"
org.eclipse.tptp.trace (4.1.0) "TPTP Trace"
org.eclipse.tptp.trace.report.birt (4.1.0.1) "BIRT Trace Reports for TPTP=
Branding Plugin"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source"
org.eclipse.wst (1.0.0) "Web Standard Tools"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers G=
uide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
de.strutsbox (2.0.0) "StrutsBox Plug-in" [Resolved]
de.strutsbox.core (2.0.0) "StrutsBox Core" [Resolved]
de.strutsbox.strutsconfig (2.0.0) "StrutsConfig Model" [Resolved]
de.strutsbox.strutsconfig.edit (2.0.0) "StrutsConfig Edit Support" [Resol=
ved]
de.strutsbox.ui (2.0.0) "StrutsBox UI" [Resolved]
de.strutsbox.visualizer (2.0.0) "StrutsBox Visualizer Model" [Resolved]
de.strutsbox.visualizer.edit (2.0.0) "Visualizer Edit Support" [Resolved]=
de.tobject.findbugs (0.0.16) "FindBugs Plug-in" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1) "Axis121 Plug-in" [Resolved]
org.apache.batik (1.5.1) "SVG Batik Toolkit" [Resolved]
org.apache.jakarta_commons_logging (1.0.3) "Jakarta Commons Logging" [Res=
olved]
org.apache.jakarta_log4j_logging (1.2.8) "Jakarta Log4J Logging" [Resolve=
d]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.2) "Ant UI" [Resolved]
org.eclipse.birt (2.0.0) "Business Intelligence and Reporting Tools" [Res=
olved]
org.eclipse.birt.chart.device.extension (2.0.0) "BIRT Chart Device Extens=
ion(s)" [Resolved]
org.eclipse.birt.chart.device.svg (2.0.0) "BIRT Chart Device SVG Extensio=
n" [Resolved]
org.eclipse.birt.chart.engine (2.0.0) "BIRT Chart Engine" [Resolved]
org.eclipse.birt.chart.engine.extension (2.0.0) "BIRT Chart Engine Extens=
ion" [Resolved]
org.eclipse.birt.chart.reportitem (2.0.0) "BIRT Chart-Report Integration"=
[Active]
org.eclipse.birt.chart.ui (2.0.0) "BIRT Chart Library UI Plug-in" [Resolv=
ed]
org.eclipse.birt.chart.ui.extension (2.0.0) "BIRT Chart UI Extension" [Re=
solved]
org.eclipse.birt.core (2.0.0) "BIRT Core Package" [Active]
org.eclipse.birt.core.ui (2.0.0) "BIRT Core UI" [Resolved]
org.eclipse.birt.data (2.0.0) "BIRT Data Engine" [Resolved]
org.eclipse.birt.data.oda (2.0.2) "BIRT Open Data Access" [Resolved]
org.eclipse.birt.data.oda.adapter.dtp (2.0.0) "DTP-BIRT ODA Adapter Plug-=
in" [Resolved]
org.eclipse.birt.doc (2.0.0) "BIRT Documentation" [Resolved]
org.eclipse.birt.report.data.oda.flatfile (2.0.0) "BIRT ODA-Flat File Dri=
ver" [Resolved]
org.eclipse.birt.report.data.oda.flatfile.ui (2.0.0) "BIRT Flat File UI P=
lug-in" [Resolved]
org.eclipse.birt.report.data.oda.jdbc (2.0.0) "BIRT ODA-JDBC Bridge Drive=
r" [Resolved]
org.eclipse.birt.report.data.oda.jdbc.ui (2.0.0) "BIRT JDBC UI Plug-in" [=
Resolved]
org.eclipse.birt.report.data.oda.sampledb (2.0.0) "BIRT Sample Database" =
[Resolved]
org.eclipse.birt.report.data.oda.sampledb.ui (2.0.0) "BIRT Sample Databas=
e UI Plug-in" [Resolved]
org.eclipse.birt.report.data.oda.xml (2.0.0) "BIRT ODA-XML Driver" [Activ=
e]
org.eclipse.birt.report.data.oda.xml.ui (2.0.0) "BIRT XML UI Plug-in" [Re=
solved]
org.eclipse.birt.report.debug.ui (2.0.0) "BIRT debug Plug-in" [Active]
org.eclipse.birt.report.designer.core (2.0.0) "BIRT Designer Core" [Resol=
ved]
org.eclipse.birt.report.designer.ui (2.0.0) "BIRT Designer UI" [Resolved]=
org.eclipse.birt.report.designer.ui.ide (2.0.0) "BIRT Designer UI for IDE=
" [Resolved]
org.eclipse.birt.report.designer.ui.lib (2.0.0) "BIRT Designer UI for Lib=
rary" [Resolved]
org.eclipse.birt.report.designer.ui.lib.explorer (2.0.0) "BIRT Library Ex=
plorer Plug-in" [Resolved]
org.eclipse.birt.report.engine (2.0.0) "BIRT Engine" [Active]
org.eclipse.birt.report.engine.emitter.html (2.0.0) "BIRT HTML Emitter" [=
Resolved]
org.eclipse.birt.report.engine.emitter.pdf (2.0.0) "BIRT PDF emitter" [Re=
solved]
org.eclipse.birt.report.model (2.0.0) "BIRT Model" [Active]
org.eclipse.birt.report.viewer (2.0.0) "BIRT Web Viewer" [Active]
org.eclipse.compare (3.1.1) "Compare Support" [Active]
org.eclipse.compare.examples (3.1.0) "Compare Example" [Resolved]
org.eclipse.compare.examples.xml (3.1.0) "XML Compare Support" [Resolved]=
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.2) "File Buffers" [Active]
org.eclipse.core.resources (3.1.2) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Managemen=
t Compatibility Fragment" [Resolved]
org.eclipse.core.resources.linux (3.1.0) "Core Resource Management Linux =
org.eclipse.core.runtime (3.1.2) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in Comp=
atibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.datatools.connectivity (0.0.2) "Data Tools Connectivity Plug-=
in" [Installed]
org.eclipse.datatools.connectivity.db.derby (1.0.0) "Derby Plug-in" [Reso=
lved]
org.eclipse.datatools.connectivity.db.generic (0.0.2) "Generic DB Connect=
ivity Plug-in" [Installed]
org.eclipse.datatools.connectivity.dbdefinition.db2.luw (0.7.0) "DB2 UDB =
Database Definition Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.derby (0.7.0) "IBM Clouds=
cape Database Definition" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.mysql (0.7.0) "DBDefiniti=
on Generic JDBC Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.oracle (0.7.0) "Oracle Da=
org.eclipse.datatools.connectivity.dbdefinition.sybase (0.7.0) "Sybase Da=
org.eclipse.datatools.connectivity.derby (0.7.0) "RDB Derby Plug-in" [Ins=
talled]
org.eclipse.datatools.connectivity.oda (3.0.0) "DTP Open Data Access" [Re=
solved]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.0) "DTP ODA Designe=
r UI Framework Plug-in" [Installed]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.0) "DTP ODA Flat Fil=
e Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.0) "DTP ODA Flat =
File Designer" [Installed]
org.eclipse.datatools.connectivity.oda.profile (3.0.0) "DTP ODA Connectio=
n Profile Framework Plug-in" [Installed]
org.eclipse.datatools.connectivity.sqm.core (0.7.0) "RDB Core" [Installed=
org.eclipse.datatools.connectivity.sqm.core.ui (0.7.0) "Core UI plugin" [=
Installed]
org.eclipse.datatools.connectivity.sqm.server.ui (0.7.0) "Server Explorer=
plugin" [Installed]
org.eclipse.datatools.connectivity.ui (0.0.2) "Data Tools Connectivity UI=
org.eclipse.datatools.connectivity.ui.dse (0.0.2) "DTP Data Source Explor=
er Plug-in" [Installed]
org.eclipse.datatools.modelbase.dbdefinition (0.7.0) "DBDefinition Model"=
[Resolved]
org.eclipse.datatools.modelbase.edit (0.7.0) "SQLModel Edit Plug-in" [Res=
olved]
org.eclipse.datatools.modelbase.sql (0.7.0) "SQLModel Plug-in" [Resolved]=
org.eclipse.datatools.modelbase.sql.query (1.0.0) "SQL Query Model Plugin=
" [Installed]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0) "SQL XML Query Mode=
l Plugin" [Installed]
org.eclipse.datatools.sqltools.common.ui (0.7.0) "Eclipse Data Tools Plat=
form SQL Tools Common UI Plug-in" [Installed]
org.eclipse.datatools.sqltools.db.derby (0.7.0) "Eclipse Data Tools Platf=
orm Derby SQL Tools Plug-in" [Installed]
org.eclipse.datatools.sqltools.db.generic (0.7.0) "Generic Database Plug-=
in" [Installed]
org.eclipse.datatools.sqltools.debugger.core (0.7.0) "Eclipse Data Tools =
Platform SQL Debugger Framework" [Installed]
org.eclipse.datatools.sqltools.editor.core (0.7.0) "DTP SQL Editor Core P=
lug-in" [Installed]
org.eclipse.datatools.sqltools.parsers.sql (1.0.0) "SQL Parser Plugin" [I=
nstalled]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.0) "Lexer Plug-in" =
[Resolved]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.0) "pluginName" [In=
stalled]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0) "SQL XML Que=
ry Parser Plug-in" [Installed]
org.eclipse.datatools.sqltools.plan (0.7.0) "SQL Execution Plan View Plug=
-in" [Installed]
org.eclipse.datatools.sqltools.result (0.7.0) "SQL Results View Plug-in" =
[Installed]
org.eclipse.datatools.sqltools.routineeditor (0.7.0) "DTP SQL Tools Routi=
ne Editor Plug-in" [Installed]
org.eclipse.datatools.sqltools.sql (0.7.0) "Eclipse Data Tools Platform S=
QL Core Plug-in" [Resolved]
org.eclipse.datatools.sqltools.sqleditor (0.7.0) "Eclipse Data Tools Plat=
form SQL Editor" [Installed]
org.eclipse.debug.core (3.1.2) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.2) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.2) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolv=
ed]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI" [=
Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI" [Reso=
lved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.2) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"=
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)" [Resol=
ved]
grammers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Ed=
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO) =
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.2) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.2) "EMF Annotated Java Importer" [Reso=
lved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping" [Res=
olved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mappin=
g Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolve=
d]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI" [R=
esolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolve=
d]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping Ed=
itor" [Resolved]
org.eclipse.emf.source (2.1.2) "Eclipse Modeling Framework (EMF) Source" =
[Resolved]
org.eclipse.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.examples.ex1 (3.1.0) "Online Help Sample" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.hyades.analysis.engine (4.1.0) "Hyades Analysis Engine" [Reso=
lved]
org.eclipse.hyades.execution (4.1.0.1) "TPTP Platform Execution Plug-In" =
[Active]
org.eclipse.hyades.execution.correlation (4.1.0) "Hyades Runtime Correlat=
ion Engine" [Resolved]
org.eclipse.hyades.execution.trace (4.1.0) "Hyades Execution Trace" [Reso=
lved]
org.eclipse.hyades.logging.adapter (4.1.0) "TPTP Monitoring Project Gener=
ic Log Adapter" [Resolved]
org.eclipse.hyades.logging.adapter.ui (4.1.0) "Generic Adapter UI" [Resol=
ved]
org.eclipse.hyades.logging.core (4.1.0.1) "Hyades Logging Agent, Common B=
ase Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.core.sample (4.1.0) "Sample for Hyades Logging=
Agent, Common Base Events and Logging Facility Support" [Resolved]
org.eclipse.hyades.logging.parsers (4.1.0) "TPTP Monitoring Project Log F=
ile Parsers" [Resolved]
org.eclipse.hyades.perfmon (4.1.0) "Perfmon StatCon Module" [Resolved]
org.eclipse.hyades.probekit (4.0.0) "Hyades Probekit" [Resolved]
org.eclipse.hyades.probekit.doc.user (4.1.0) "Probekit User Documentation=
" [Resolved]
org.eclipse.hyades.probekit.ui (4.1.0) "Probe Editor" [Resolved]
org.eclipse.hyades.resources.database (4.1.0) "Hyades Core Resource Exten=
sions" [Resolved]
org.eclipse.hyades.sdb (4.1.0) "Symptom Database tool" [Resolved]
org.eclipse.hyades.statistical.ui (4.1.0) "Statistical Analysis" [Active]=
org.eclipse.hyades.test.core (4.1.0) "TPTP Test Core Plug-In" [Active]
org.eclipse.hyades.test.doc.user (4.1.0) "Test Tools user documentation" =
[Resolved]
org.eclipse.hyades.test.tools.core (4.1.0) "TPTP Test Tools Core Plug-In"=
[Active]
org.eclipse.hyades.test.tools.ui (4.1.0) "TPTP Test Tools UI Plug-In" [Ac=
tive]
org.eclipse.hyades.test.ui (4.1.0.1) "TPTP Test UI Plug-In" [Active]
org.eclipse.hyades.trace.sample (4.1.0) "Samples for the TPTP Monitoring =
Tools Plugins" [Resolved]
org.eclipse.hyades.trace.ui (4.1.0.1) "Hyades Trace Core UI" [Active]
org.eclipse.hyades.trace.views (4.1.0) "Hyades Trace Views Plugin" [Resol=
ved]
org.eclipse.hyades.ui (4.1.0) "Hyades UI" [Active]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.2) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.1.2) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.2) "Eclipse JDT Plug-in Developer Guide" [Re=
solved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide" [R=
esolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support" [Res=
olved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runti=
me support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Suppo=
rt" [Active]
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK" [Reso=
lved]
org.eclipse.jdt.ui (3.1.2) "Java Development Tools UI" [Active]
org.eclipse.jdt.ui.examples.projects (3.1.1) "Java Development Tools Exam=
ple Projects" [Resolved]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo (Introspectio=
n) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]=
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support" [R=
esolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.2) "JFace Text" [Active]
org.eclipse.jsf (0.1.0) "JavaServer Faces Tools" [Resolved]
org.eclipse.jsr220orm (0.9.4) "JSR220-ORM" [Resolved]
org.eclipse.jsr220orm.core (0.9.4) "JSR220-ORM Core" [Resolved]
org.eclipse.jsr220orm.generic (0.9.4) "JSR220-ORM Generic EJB3 Support" [=
Resolved]
org.eclipse.jsr220orm.hibernate (0.9.4) "JSR220-ORM Hibernate Support" [R=
esolved]
org.eclipse.jsr220orm.metadata (0.9.4) "JSR220-ORM Metadata Model" [Resol=
ved]
org.eclipse.jsr220orm.metadata.edit (0.9.4) "JSR220-ORM Metadata Edit" [R=
esolved]
org.eclipse.jsr220orm.ui (0.9.4) "JSR220-ORM UI" [Resolved]
org.eclipse.jst (1.0.0) "J2EE Standard Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (1.0.0) "Annotation Control=
ler Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.0.0) "Annotation Core Plug-in"=
[Resolved]
org.eclipse.jst.common.annotations.ui (1.0.0) "Annotations UI Plug-in" [R=
esolved]
org.eclipse.jst.common.frameworks (1.0.0) "Integration Plug-in" [Resolved=
org.eclipse.jst.common.navigator.java (1.0.0) "Navigator Plug-in" [Resolv=
ed]
org.eclipse.jst.common.project.facet.core (1.0.0) "Project Facet Core (Ja=
va Support)" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.0) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.0.0) "WTP EJB UI Plug-in" [Resolved]
org.eclipse.jst.j2ee (1.0.0) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.0.0) "J2EE Core Component" [Active]
org.eclipse.jst.j2ee.doc.user (1.0.0) "J2EE tools documentation" [Resolve=
d]
org.eclipse.jst.j2ee.ejb (1.0.0) "EJB component Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (1.0.0) "EJB Annotation Model P=
lug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.0.0) "EJB Emitter Plug-in=
" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.0.0) "EJB Annotations Ui Plug-=
in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.0.0) "Xdoclet Annotations=
Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.0) "J2EE tools infopops" [Resolved]
org.eclipse.jst.j2ee.jca (1.0.0) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.0.0) "WTP JCA UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.0.0) "J2EE Extensions to Common Navi=
gator" [Resolved]
org.eclipse.jst.j2ee.ui (1.0.0) "WTP J2EE UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.web (1.0.0) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (1.0.0) "Web Service Plug-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.0.0) "WTP Webservice UI Plug-in" [R=
esolved]
org.eclipse.jst.j2ee.xdoclet.runtime (1.0.0) "XDocletRuntime Plug-in" [Re=
solved]
org.eclipse.jst.jsp.core (1.0.0) "Structured Source JSP Model" [Resolved]=
org.eclipse.jst.jsp.ui (1.0.0) "SSE JSP Source Editor" [Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.0) "JSP tools infopops" [Resolved]
org.eclipse.jst.server.core (1.0.0) "Java Server Support" [Resolved]
org.eclipse.jst.server.generic.core (1.0.0) "Generic Server Plugin" [Reso=
lved]
org.eclipse.jst.server.generic.serverdefinitions (1.0.0) "Oracle OC4J v10=
=2E1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.0) "Generic Server Plugin UI" [Res=
olved]
org.eclipse.jst.server.jboss (1.0.0) "Generic server example definitions"=
[Resolved]
org.eclipse.jst.server.tomcat.core (1.0.0) "Apache Tomcat Support" [Resol=
ved]
org.eclipse.jst.server.tomcat.ui (1.0.0) "Apache Tomcat UI Support" [Reso=
lved]
org.eclipse.jst.server.ui (1.0.0) "Java Server UI Support" [Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.0) "Apache Tomcat for Server Tool=
s documentation" [Resolved]
org.eclipse.jst.server.ui.infopop (7.0.0) "Server Tools infopops for J2EE=
org.eclipse.jst.server.websphere.core (1.0.0) "WebSphere Generic Server D=
org.eclipse.jst.servlet.ui (1.0.0) "WTP Servlet UI Plug-in" [Resolved]
org.eclipse.jst.ws (1.0.0) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.0) "Web service Axis Consum=
ption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.0) "Webservice Axis Consumpti=
on UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.0) "Webservice Axis Creation UI"=
[Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.0) "Web services Axis UI" [Resolved]=
org.eclipse.jst.ws.axis.ui.doc.user (1.0.0) "Plugin.name" [Resolved]
org.eclipse.jst.ws.consumption (1.0.0) "Web Services Consumption" [Resolv=
ed]
org.eclipse.jst.ws.consumption.infopop (1.0.0) "Web services UI" [Resolve=
d]
org.eclipse.jst.ws.consumption.ui (1.0.0) "Web Services Consumption Graph=
ical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.0) "Web service consumpti=
on documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0) "Web Services Creation EJB Gra=
phical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.0) "Web Services Creation Graphical U=
org.eclipse.jst.ws.doc.user (1.0.0) "Web services UI" [Resolved]
org.eclipse.jst.ws.infopop (1.0.0) "Web services UI" [Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.0) "Web Services Universal Descripti=
on Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.0) "Web Services Graphical User Interface" [Re=
solved]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.2) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolv=
ed]
org.eclipse.pde.build (3.1.2) "Plug-in Development Environment Build Supp=
ort" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.2) "Eclipse Plug-in Development User Guide"=
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]=
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"=
[Active]
eveloper Resources" [Resolved]
org.eclipse.pde.ui (3.1.2) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.2) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.2) "Eclipse Platform Plug-in Developer =
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide" [Res=
olved]
org.eclipse.platform.source.linux.gtk.x86 (3.1.2) "Eclipse Platform Plug-=
in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources" =
[Resolved]
org.eclipse.rcp.source.linux.gtk.x86 (3.1.2) "Eclipse RCP Plug-in Develop=
org.eclipse.sdk (3.1.2) "Eclipse Project SDK" [Resolved]
org.eclipse.sdk.examples (3.1.1) "Eclipse SDK Examples" [Resolved]
org.eclipse.sdk.examples.source (3.1.1) "Eclipse Platform Plug-in Develop=
org.eclipse.search (3.1.2) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.examples (3.1.0) "SWT Standalone Examples Plugin" [Resolv=
ed]
org.eclipse.swt.examples.browser (3.1.0) "SWT Browser Example Plugin" [Re=
solved]
org.eclipse.swt.examples.browser.demos (3.1.0) "SWT Browser Demos Plugin"=
[Resolved]
org.eclipse.swt.examples.controls (3.1.0) "SWT Controls Example Plugin" [=
Resolved]
org.eclipse.swt.examples.launcher (3.1.0) "SWT Launcher Example Plugin" [=
Resolved]
org.eclipse.swt.examples.layouts (3.1.0) "SWT Layout Example Plugin" [Res=
olved]
org.eclipse.swt.examples.paint (3.1.0) "SWT Paint Example Plugin" [Resolv=
ed]
org.eclipse.swt.gtk.linux.x86 (3.1.1) "Standard Widget Toolkit for GTK 2.=
0" [Resolved]
org.eclipse.target (1.0.0) "Target Plug-in" [Resolved]
org.eclipse.target.ftp (1.0.0) "Ftp Plug-in" [Resolved]
org.eclipse.target.ide (1.0.0) "Target IDE Plug-in" [Resolved]
org.eclipse.target.iofile (1.0.0) "I/O File Plug-in" [Resolved]
org.eclipse.target.webdav (1.0.0) "Target WebDAV Plug-in" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Active]
org.eclipse.team.examples.filesystem (3.1.0) "Eclipse Team File System Ex=
ample" [Active]
org.eclipse.team.extras (3.1.0) "Eclipse FTP and WebDAV Support" [Resolve=
d]
org.eclipse.team.extras.source (3.1.0) "Eclipse Team Extras Plug-in Devel=
org.eclipse.team.ftp (3.1.0) "FTP Deployment Provider" [Resolved]
org.eclipse.team.target (1.0.0) "Team Target Plug-in" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Active]
org.eclipse.team.webdav (3.1.0) "WebDAV Team Provider" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.tptp.choreography (4.1.0) "TPTP Choreography" [Resolved]
org.eclipse.tptp.monitoring (4.1.0) "TPTP Monitoring" [Resolved]
org.eclipse.tptp.monitoring.doc.user (4.1.0) "TPTP Monitoring Tools Docum=
org.eclipse.tptp.monitoring.logui (4.1.0.1) "Logui Plug-in" [Resolved]
ver Logging Utility" [Resolved]
or TPTP Branding Plugin" [Resolved]
org.eclipse.tptp.monitoring.report.birt.ui (4.1.0.1) "BIRT Monitor Report=
s for TPTP" [Active]
org.eclipse.tptp.platform.agentcontroller (4.1.0.1) "TPTP Agent Controlle=
r" [Resolved]
org.eclipse.tptp.platform.agentcontroller.doc.user (4.1.0) "Agent Control=
ler documentation" [Resolved]
org.eclipse.tptp.platform.analysis (4.1.0) "TPTP Analysis" [Resolved]
org.eclipse.tptp.platform.analysis.core (4.1.0) "TPTP Analysis Framework =
org.eclipse.tptp.platform.analysis.core.ui (4.1.0) "Rational Analysis Fra=
mework User Interface Plug-in" [Resolved]
org.eclipse.tptp.platform.analysis.engine (4.1.0) "TPTP Analysis Engine" =
[Resolved]
org.eclipse.tptp.platform.collection.framework (4.1.0) "TPTP Collection F=
org.eclipse.tptp.platform.core (4.1.0) "TPTP Platform" [Resolved]
org.eclipse.tptp.platform.doc.user (4.1.0) "TPTP Platform Project Documen=
tation" [Resolved]
org.eclipse.tptp.platform.log.views (4.1.0) "Hyades Log UI" [Active]
org.eclipse.tptp.platform.lta (4.1.0) "TPTP Log and Trace Analyzer" [Reso=
lved]
org.eclipse.tptp.platform.models (4.1.0.1) "Hyades Models" [Active]
org.eclipse.tptp.platform.probekit (4.1.0) "TPTP ProbeKit" [Resolved]
r" [Resolved]
org.eclipse.tptp.platform.profile.server.core (4.1.0.1) "TPTP Profile On =
Server Core" [Resolved]
org.eclipse.tptp.platform.profile.server.wst (4.1.0.1) "TPTP Profile On S=
erver WTP Utility" [Active]
org.eclipse.tptp.platform.report (4.1.0) "TPTP Charting Service" [Resolve=
d]
Branding plugin" [Resolved]
org.eclipse.tptp.platform.report.birt.ui (4.1.0.1) "BIRT Reporting for TP=
TP" [Active]
org.eclipse.tptp.platform.report.core (4.1.0) "TPTP Report Framework" [Ac=
tive]
org.eclipse.tptp.platform.report.ui (4.1.0.1) "TPTP Report UI" [Resolved]=
org.eclipse.tptp.platform.samples (4.1.0) "TPTP Platform Samples" [Resolv=
ed]
org.eclipse.tptp.platform.statistical.ui (4.1.0) "TPTP Statistical UI" [R=
esolved]
org.eclipse.tptp.platform.trace (4.1.0) "TPTP Platform Trace" [Resolved]
org.eclipse.tptp.test (4.1.0) "TPTP Test" [Resolved]
back" [Resolved]
org.eclipse.tptp.test.auto.gui (4.1.0) "TPTP Automated GUI Test Tool" [Ac=
tive]
org.eclipse.tptp.test.report.birt.ui (4.1.0.1) "Ui Plug-in" [Active]
org.eclipse.tptp.test.samples (4.1.0) "TPTP Test Samples" [Active]
org.eclipse.tptp.test.tools (4.1.0) "TPTP Test Tools" [Resolved]
org.eclipse.tptp.trace (4.1.0) "TPTP Trace" [Resolved]
org.eclipse.tptp.trace.report.birt.ui (4.1.0.1) "BIRT Trace Reports for T=
PTP" [Active]
org.eclipse.ui (3.1.2) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.2) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.examples.javaeditor (3.1.1) "JFace Text Example" [Resolved=
org.eclipse.ui.examples.multipageeditor (3.1.0) "Multi-Page Editor Exampl=
e" [Resolved]
org.eclipse.ui.examples.propertysheet (3.1.0) "User File Editor" [Resolve=
d]
org.eclipse.ui.examples.readmetool (3.1.0) "Readme File Editing Tool" [Re=
solved]
org.eclipse.ui.examples.undo (3.1.0) "Undo Example" [Resolved]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in" [Reso=
lved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.workbench (3.1.2) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility" =
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.2) "Text Editor Framework" [Acti=
ve]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator" [Ac=
tive]
org.eclipse.update.core (3.1.2) "Install/Update Core" [Resolved]
org.eclipse.update.core.linux (3.1.0) "Install/Update Core for Linux" [Re=
solved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Activ=
e]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Resolved=
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]=
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Resolved]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes" =
[Resolved]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet" [Res=
olved]
org.eclipse.ve.sdk (1.1.0) "Visual Editor SDK" [Resolved]
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source" [Resolved]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit" =
[Resolved]
org.eclipse.webdav (3.0.0) "WebDAV Client" [Resolved]
org.eclipse.wst (1.0.0) "Web Standard Tools" [Resolved]
org.eclipse.wst.command.env (1.0.0) "Environment Command Framework (headl=
ess)" [Resolved]
org.eclipse.wst.command.env.core (1.0.0) "Environment Command Framework (=
core)" [Resolved]
org.eclipse.wst.command.env.ui (1.0.0) "Environment Command Framework (GU=
I)" [Resolved]
org.eclipse.wst.common.emf (1.0.0) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.0.0) "EMF Workbench Ed=
it Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.0) "Enviornment Plug-in" [Resolve=
d]
org.eclipse.wst.common.frameworks (1.0.0) "org.eclipse.wst.common.framewo=
rks" [Active]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Active]
org.eclipse.wst.common.infopop (1.0.0) "Common WST infopops" [Resolved]
org.eclipse.wst.common.modulecore (1.0.0) "Modulecore Plug-in" [Active]
org.eclipse.wst.common.navigator.views (1.0.0) "Common Navigator View" [R=
esolved]
org.eclipse.wst.common.navigator.workbench (1.0.0) "Navigator Workbench C=
omponents" [Resolved]
org.eclipse.wst.common.project.facet.core (1.0.0) "Project Facet Core" [A=
ctive]
org.eclipse.wst.common.project.facet.ui (1.0.0) "Project Facet UI" [Resol=
ved]
org.eclipse.wst.common.snippets (1.0.0) "Snippets View" [Resolved]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Active]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI" [Reso=
lved]
org.eclipse.wst.common.uriresolver (1.0.0) "Common URI Resolver Framework=
" [Active]
org.eclipse.wst.css.core (1.0.0) "Structured Source CSS Model" [Active]
org.eclipse.wst.css.ui (1.0.0) "SSE CSS Source Editor" [Active]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.0) "Data documentat=
ion" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.0) "Data documentation" [Re=
solved]
org.eclipse.wst.datatools.server.ui.doc.user (1.0.0) "Data server documen=
tation" [Resolved]
org.eclipse.wst.doc.user (1.0.0) "master user doc toc" [Resolved]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.0) "DTD infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.0) "DTD Editor documentation" [Re=
solved]
org.eclipse.wst.html.core (1.0.0) "Structured Source HTML Model" [Active]=
org.eclipse.wst.html.standard.dtds (1.0.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (1.0.0) "HTML UI Source Editor" [Active]
org.eclipse.wst.html.ui.infopop (1.0.0) "HTML editor infopops" [Resolved]=
org.eclipse.wst.internet.cache (1.0.0) "Cache URI Resolver Plug-in" [Reso=
lved]
org.eclipse.wst.internet.monitor.core (1.0.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (1.0.0) "Internet Proxy Preferences" [Acti=
ve]
org.eclipse.wst.internet.proxy.infopop (1.0.0) "Internet Proxy Infopops" =
[Resolved]
org.eclipse.wst.javascript.core (1.0.0) "Structured Source JavaScript Mod=
el" [Active]
org.eclipse.wst.javascript.ui (1.0.0) "SSE JavaScript Source Editor" [Act=
ive]
org.eclipse.wst.javascript.ui.infopop (1.0.0) "Javascript infopop" [Resol=
ved]
org.eclipse.wst.rdb.connection.ui (1.0.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0) "New Connection wizard =
org.eclipse.wst.rdb.core (1.0.0) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.0) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.data.core (1.0.0) "Data Core Plugin" [Resolved]
org.eclipse.wst.rdb.data.ui (1.0.0) "Data UI Plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries Dat=
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.0) "DB2 UDB Database Defini=
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.0) "DB2 UDB Database De=
org.eclipse.wst.rdb.dbdefinition.derby (1.0.0) "IBM Cloudscape Database D=
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0) "Informix Database Defi=
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.0) "DBDefinition Mysql Plug-i=
n" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0) "Oracle Database Definiti=
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.0) "SQL Server Database D=
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.0) "Sybase Database Definiti=
org.eclipse.wst.rdb.derby (1.0.0) "RDB Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0) "RDB Derby Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.0) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.0) "FE Ui Actions Plug-in" [Resolv=
ed]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0) "Generate DDL wizard infopops" =
[Resolved]
org.eclipse.wst.rdb.models.dbdefinition (1.0.0) "DBDefinition Model" [Res=
olved]
org.eclipse.wst.rdb.models.sql (1.0.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.0) "SQLModel Edit Plug-in" [Reso=
lved]
org.eclipse.wst.rdb.mysql (1.0.0) "RDB Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (1.0.0) "Data Output Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0) "Data Output view infopops=
" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.0) "Server Explorer Extensions=
Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0) "Server Explorer plugin" [Resolved]=
org.eclipse.wst.rdb.server.ui.infopop (1.0.0) "Server Explorer view infop=
ops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.0) "SQL Source Editor Plugin" [Resolve=
d]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0) "SQL infopops" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0) "Sqlscrapbook Plug-in" [Resolved=
org.eclipse.wst.server.core (1.0.0) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.0) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.0) "Managing se
Previous Topic:Code Coverage within a method
Next Topic:Need help detecting agent
Current Time: Sun May 20 19:51:24 GMT 2018
Powered by FUDForum. Page generated in 0.02303 seconds
