Home » Newcomers » Newcomers » Checking whether workspace is in use(/.metadata/.lock no longer works)
Checking whether workspace is in use [message #541760] Tue, 22 June 2010 12:55 Go to next message
Rodrigo Hjort is currently offline Rodrigo HjortFriend
In a shell script in Linux I need to check whether a given workspace directory is in use by an open Eclipse instance.
In order to perform that, I used to look for this zeroed file: WORKSPACE/.metadata/.lock
However, it seems the current Eclipse 3.5 checking is no longer based on that file, as the latter remains stored in the directory even after closing the IDE.
So, how that workspace checking is made currently?
Thanks in advance.
Rodrigo Hjort
http://agajorte.blogspot.com
Re: Checking whether workspace is in use [message #541807 is a reply to message #541760] Tue, 22 June 2010 15:08 Go to previous messageGo to next message
Rodrigo,
I think that's still being used. Perhaps a crashed Eclipse left one
behind. Perhaps you should check by attempting to open an output stream
to the file, which should result in a failure because it is "in use" by
Eclipse.
> closing the IDE.
> Thanks in advance.
> Rodrigo Hjort
Re: Checking whether workspace is in use [message #541843 is a reply to message #541807] Tue, 22 June 2010 17:32 Go to previous messageGo to next message
Ed,
Eclipse 3.5 definitely seems to ignore .lock file.
Firstly, I started the IDE switching to a brand new worskpace. Then, there was the 0-bytes .lock file. But strangely it remains in .metadata directory after closing Eclipse.
/tmp/ws/.metadata$ ls -la
total 76
drwxr-xr-x 4 user group 4096 2010-06-22 14:00 .
drwxr-xr-x 4 user group 4096 2010-06-22 14:00 ..
-rw-r--r-- 1 user group 0 2010-06-22 14:00 .lock
-rw-r--r-- 1 user group 49973 2010-06-22 14:01 .log
drwxr-xr-x 3 user group 4096 2010-06-22 14:00 .mylyn
drwxr-xr-x 57 user group 4096 2010-06-22 14:00 .plugins
-rw-r--r-- 1 user group 26 2010-06-22 14:01 version.ini
Secondly, I tried to create another .lock file with an output stream (ls > .lock) as you suggested. I opened Eclipse and no error of workspace in use was raised.
Here are the version specifications:
Eclipse SDK
Version: 3.5.2
Build id: M20100211-1343
Any other suggestion?
Re: Checking whether workspace is in use [message #541867 is a reply to message #541843] Tue, 22 June 2010 19:51 Go to previous message
David Wegener is currently offline David WegenerFriend
"Rodrigo Hjort" <rodrigo_hjort@yahoo.com> wrote in message
news:hvqs3g$t0o$1@build.eclipse.org...
> Ed,
> total 76
> was raised.
> Eclipse SDK
> Version: 3.5.2
Eclipse workspace locking has become much more sophisticated over the years.
Simply checking for the existence of a .lock file would prevent Eclipse from
starting after a crash. Now Eclipse uses the java nio file locking
mechanism to lock the file. The file locks are release if the process
crashs so subsquent attempts to start Eclipse will be successful. However,
if you try to lock the file while Eclipse has the lock intact, it will fail.
You should be able to use a similar technique to check to see if Eclipse has
the workspace directory open.
Previous Topic:Export eclipse installation
Next Topic:Problem with package structure
Current Time: Sun May 27 23:39:06 GMT 2018
Powered by FUDForum. Page generated in 0.02563 seconds
