How to disable auto update for the BIRT plugins? [message #540893] |
Thu, 17 June 2010 14:49 |
Louay Rukieh Messages: 1 Registered: June 2010 |
Junior Member |
I'm using BIRT runtime on AIX in a script that run genReport.sh against a list of targets. The problem I began experiencing is a delay in creating the report because each time it does run the genReprot.sh it tries to update the plugin and fails. This process is causing the report generation to take more than 10 hours on what used to be 2 hours.
This is the message I keep on seeing in the output (for each time it runs the genReport.sh)
!ENTRY org.eclipse.update.configurator 2010-06-16 09:44:51.579
!MESSAGE Could not install bundle update@plugins/org.eclipse.emf.common_2.2.1.v200702131851.jar The activator org.eclips
e.emf.common.CommonPlugin$Implementation for bundle org.eclipse.emf.common is invalid
I'm using Birt Runtime 2.2.1.
Thanks for you help in advance.
FUDForum. Page generated in 0.02408 seconds
