Home » Eclipse Projects » JFace » Widgets in tables
Widgets in tables [message #540491] Wed, 16 June 2010 11:49 Go to next message
Alexey Romanov is currently offline Alexey RomanovFriend
I've found this old thread from 2006 which said TableViewer would likely support putting arbitrary widgets in table cells in JFace 3.3.
At first I thought that was what CellLabelProvider was supposed to do, and I could just override update(ViewerCell), but ViewerCell doesn't have a setWidget method.
Are the ugly workarounds with TableEditor still needed just to put some buttons into table cells?
Re: Widgets in tables [message #540986 is a reply to message #540491] Thu, 17 June 2010 21:18 Go to previous message
Tim  is currently offline Tim Friend
I dont know the old thread, but i can give you some tips
for special widgets in the viewer.
You can set the following widgets in a cell:
- BooleanCellEditor
- CheckBoxCellEditor
- DialogCellEditor
- TextCellEditor
etc.
For this topic exist very nice snippets:
- Snippet054NativeControlsInViewers
- Snippet62TextAndDialogCellEditor
- Snippet056BooleanCellEditor
- Snippet048TreeViewerTabWithCheckboxFor3_3
- Snippet034CellEditorPerRowNewAPI
Google for this snippets and you will find directly the pure code.
Hope this hels.
Tim
Previous Topic:TreeViewer with Columns
Next Topic:Using EditingSupport Class with the table viewer
Current Time: Wed Jun 20 06:17:31 GMT 2018
Powered by FUDForum. Page generated in 0.02235 seconds
