com.ibm.icu and Birt plugin (Eclipse PDE)? [message #539634] |
Fri, 11 June 2010 14:48 |
bob Messages: 60 Registered: July 2009 |
Member |
I have made a Birt application which use the com.ibm.icu and
org.eclipse.report.engine libraries.
I have packaged this application into a jar with all its dependencies (using
maven).
I have converted this jar into a plugin using the eclipse "Plug-in from
Existing JAR Archives".
I then add this plugin as a dependency for another plugin.
But to make the plugin version of the application work (else I get an error
at runtime) I need to add (again) :
com.ibm.icu
under the dependencies in the MANIFEST file for the plugin which is made
from the jar file.
Any ideas on why I have to add these dependencies in the MANIFEST file even
though they are already present in the jar file?
FUDForum. Page generated in 0.03163 seconds
