BIRT RCP Designer and JNDI [message #539172] |
Wed, 09 June 2010 20:37 |
John Dunlap Messages: 4 Registered: June 2010 |
Junior Member |
Greetings,
I have built a merged war using the BIRT Report Viewer and some in-house code. Specifically, I integrated the viewer with spring security, Active Directory, and added some administrative UI screens.
The process that we would like to use is for people who create reports to create them using the RCP report designer and then to upload them into the report viewer where users can access the newly created report(s). However, we have a requirement that the database credentials (specifically the username and password) CANNOT be present in the rptdesign file in any way shape manner or form. We want the report to use a JNDI datasource in the report viewer and we also want the report to use a JNDI datasource in the report designer, to avoid the database credentials being saved in that file. The plan is to have the upload mechanism in the report viewer issue a validation error if the database username/password fields are found in the rptdesign file (or perhaps silently remove them, if a valid JNDI name is also present).
The problem that I am facing is that I cannot find a way to create a local JNDI datasource, within the designer, that would allow me to simply set a JNDI name in the create datasource dialog when creating a JDBC datasource.
Any thoughts or suggestions would be greatly appreciated.
-John
Re: BIRT RCP Designer and JNDI [message #539192 is a reply to message #539172] |
Wed, 09 June 2010 21:47 |
John,
Take a look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197443
Jason
On 6/9/2010 4:37 PM, John Dunlap wrote:
> Greetings,
> JDBC datasource.
> -John
Re: BIRT RCP Designer and JNDI [message #539342 is a reply to message #539195] |
Thu, 10 June 2010 13:40 |
John,
Can you add your comments to the bug?
Jason
On 6/9/2010 5:58 PM, John Dunlap wrote:
> Yes, that feature is exactly what I'm looking for. Sadly, from reading
> the posts, it doesn't appear to have been implemented. This is a bit of
> a problem, in my situation, because although I can have my upload
> controller automatically remove the database credentials from the
> rptdesign file, I do not trust some of our potential report writers to
> manually remove them before committing the rptdesign file into
> subversion...
FUDForum. Page generated in 0.03523 seconds
