Re: how can I display a report at the center of BIRT viewer? [message #539184 is a reply to message #539158] |
Wed, 09 June 2010 21:29 |
The default in the viewer is to show to the left. You can always add a
grid with one column and one cell and put the contents of the report
into the one cell. On the cell properties choose the center button.
Jason
On 6/9/2010 3:27 PM, Mehrab wrote:
> Hi all
> I am using BIRT 2.5.1. When I display a report in HTML format using BIRT
> web viewer, it show the report at the right side of the viewer. I am
> using fixed layout. Is their any way to show the report at the center of
> viewer?
> Please help me.
> Thanks in advance.
Re: how can I display a report at the center of BIRT viewer? [message #539355 is a reply to message #539275] |
Thu, 10 June 2010 14:05 |
Create a new style but use the predefined style named table. Select
text block and choose text alignment center. See attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="8">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
<style name="table" id="86">
<property name="textAlign">center</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-header>
<auto-text id="7">
<property name="type">page-variable</property>
<property name="pageVariable">test</property>
</auto-text>
</page-header>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="48">
<column id="49"/>
<row id="50">
<cell id="51">
<property name="textAlign">right</property>
</cell>
</row>
</grid>
<table id="52">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="81"/>
<column id="82"/>
<column id="83"/>
<column id="84"/>
<column id="85"/>
<header>
<row id="53">
<cell id="54">
<label id="55">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="56">
<label id="57">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="58">
<label id="59">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="60">
<label id="61">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="62">
<label id="63">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="64">
<cell id="65">
<data id="66">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="67">
<data id="68">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="69">
<data id="70">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="71">
<data id="72">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="73">
<data id="74">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="75">
<cell id="76"/>
<cell id="77"/>
<cell id="78"/>
<cell id="79"/>
<cell id="80"/>
</row>
</footer>
</table>
</body>
<property name="pageVariables">
<variable-element name="test">
<expression name="value"
type="javascript">BirtStr.trim("");</expression>
<property name="type">report</property>
</variable-element>
</property>
</report>
On 6/10/2010 5:11 AM, Mehrab wrote:
> Jason
> Thank your for your quick reply. But solution is not working because I
> am using "fixed layout". It render HTML report with style
> "table-layout: fixed;". So show the report at the left side.
> Is their any way to change predefined style and show the report at center?
> Thank you.
> Mehrab
FUDForum. Page generated in 0.04179 seconds
